주요 콘텐츠로 건너뛰기
Panasonic Lumix DMC-TZ5 AV port circuit board Replacement
필요한 것
  1. Panasonic Lumix DMC-TZ5 AV port circuit board Replacement, Back Cover: 1 단계, 이미지 1/1
    • Remove the battery and memory card from the device.
  2. Panasonic Lumix DMC-TZ5 AV port circuit board Replacement: 2 단계, 이미지 1/1
    • Remove 4 screws from the right side of the camera.
    • There are two 3.4mm screws at the top.
    • There are two 2.2mm screws at the bottom.
  3. Panasonic Lumix DMC-TZ5 AV port circuit board Replacement: 3 단계, 이미지 1/1
    • Remove the single 3.4mm screw on the left side of the camera.
  4. Panasonic Lumix DMC-TZ5 AV port circuit board Replacement: 4 단계, 이미지 1/1
    • Remove 5 screws from the base of the camera.
    • There are two 2.2mm screws next to the battery compartment.
    • There are three 4mm screws around the tripod mount.
  5. Panasonic Lumix DMC-TZ5 AV port circuit board Replacement: 5 단계, 이미지 1/1
    • Slowly slide the back cover away from the device
    • The back casing is held in place by two ribbon cables. Do not pull the back cover too far from the camera.
  6. Panasonic Lumix DMC-TZ5 AV port circuit board Replacement: 6 단계, 이미지 1/2 Panasonic Lumix DMC-TZ5 AV port circuit board Replacement: 6 단계, 이미지 2/2
    • Detach both ribbon cables using a spudger.
    • Use the tip of the spudger to lift the black clip upward, unlocking the ribbon cable.
  7. Panasonic Lumix DMC-TZ5 AV port circuit board Replacement: 7 단계, 이미지 1/1
    • Remove the back casing from the camera.
  8. Panasonic Lumix DMC-TZ5 AV port circuit board Replacement, button board: 8 단계, 이미지 1/2 Panasonic Lumix DMC-TZ5 AV port circuit board Replacement, button board: 8 단계, 이미지 2/2
    • Use the spudger to remove the ribbon cable connecting the lens casing to the circuit board by lifting up the black clip.
    • Carefully remove the function switch cover. This unit snaps on and off.
  9. Panasonic Lumix DMC-TZ5 AV port circuit board Replacement: 9 단계, 이미지 1/1
    • Carefully unsnap the front logic board from the rear logic board using a spudger.
  10. Panasonic Lumix DMC-TZ5 AV port circuit board Replacement: 10 단계, 이미지 1/2 Panasonic Lumix DMC-TZ5 AV port circuit board Replacement: 10 단계, 이미지 2/2
    • Slide the entire top part of the camera that is attached to the logic board, horizontally away from the camera.
  11. Panasonic Lumix DMC-TZ5 AV port circuit board Replacement: 11 단계, 이미지 1/3 Panasonic Lumix DMC-TZ5 AV port circuit board Replacement: 11 단계, 이미지 2/3 Panasonic Lumix DMC-TZ5 AV port circuit board Replacement: 11 단계, 이미지 3/3
    • Remove the ribbon cable from the top connection panel by unlocking the black clip with a spudger.
    • This leaves you with the logic board and the top connection panel separate and free from the camera
  12. Panasonic Lumix DMC-TZ5 AV port circuit board Replacement, Camera Lens Assembly: 12 단계, 이미지 1/1
    • Use a spudger to detach the ribbon cable from the circuit board. Lift the black clip up to unlock it as before.
  13. Panasonic Lumix DMC-TZ5 AV port circuit board Replacement: 13 단계, 이미지 1/1
    • Remove the 3 screws holding the lens assembly in place.
    • The two screws on the left are 4.5mm with washers.
    • The single screw on the right is 4mm.
  14. Panasonic Lumix DMC-TZ5 AV port circuit board Replacement: 14 단계, 이미지 1/1
    • Push the lens assembly slightly toward the circuit board, and pull the left side out of the casing first. You will have to wiggle this out gently.
  15. Panasonic Lumix DMC-TZ5 AV port circuit board Replacement: 15 단계, 이미지 1/2 Panasonic Lumix DMC-TZ5 AV port circuit board Replacement: 15 단계, 이미지 2/2
    • Remove the entire assembly out of the casing.
    • The ribbons on the left and bottom of the assembly simply rest on the camera housing.
  16. Panasonic Lumix DMC-TZ5 AV port circuit board Replacement, AV port circuit board: 16 단계, 이미지 1/1
    • Use the spudger to unclip the top ribbon cable from the circuit board.
  17. Panasonic Lumix DMC-TZ5 AV port circuit board Replacement: 17 단계, 이미지 1/1
    • Remove the single 2mm screw in the bottom right corner of the circuit board
  18. Panasonic Lumix DMC-TZ5 AV port circuit board Replacement: 18 단계, 이미지 1/2 Panasonic Lumix DMC-TZ5 AV port circuit board Replacement: 18 단계, 이미지 2/2
    • Gently slide the circuit board out away from the port connections. Pull it toward where the lens used to be. Some wiggling may be necessary to remove.
    • The circuit board is fitted into slots attached to the side of the camera. Do not angle upwards to remove.
  19. Panasonic Lumix DMC-TZ5 AV port circuit board Replacement: 19 단계, 이미지 1/1
    • Take note of how the slots fit into the circuit board for easy replacement.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Kevin Lufkin
회원 가입일: 10/11/10
158 평판
안내서 2개 작성하였습니다
Cal Poly, Team 9-21, Regan Fall 2010 Cal Poly, Team 9-21, Regan Fall 2010 회원
CPSU-REGAN-F10S9G21
4 회원들
안내서 14개 작성하였습니다
댓글 한 개
Where can I buy this part? Thanks!
Janx38 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 15
전체 시간: 8,380
