소개
Step by step guide to replacing your digital camera door.
도구
부품
Remove the battery and memory card from the unit
Remove 6 (0.3mm) screws from the sides of the unit
Remove 5 (0.3mm) screws from the bottom of the unit
Pull out door pin using needle nose pliers or other tool.
Notice spring positioning. This will help you re-install your replacement door
거의 끝나갑니다!
결론
