주요 콘텐츠로 건너뛰기
Panasonic Lumix DMC-ZS25 Power Button Replacement
필요한 것
  1. Panasonic Lumix DMC-ZS25  Power Button Replacement, Unscrewing your Panasonic Lumix: 1 단계, 이미지 1/3 Panasonic Lumix DMC-ZS25  Power Button Replacement, Unscrewing your Panasonic Lumix: 1 단계, 이미지 2/3 Panasonic Lumix DMC-ZS25  Power Button Replacement, Unscrewing your Panasonic Lumix: 1 단계, 이미지 3/3
    • Open the four 3.40 mm screws from the right and left sides of your Panasonic Lumix Camera.
    • Remove the two 2.60 mm screws located next to the battery.
  2. Panasonic Lumix DMC-ZS25  Power Button Replacement: 2 단계, 이미지 1/1
    • Use the plastic opening tool to open the outer cover of your device.
    • The easiest place to open your device is from the HDMI port.
    • Open it gently to avoid breaking the cover.
  3. Panasonic Lumix DMC-ZS25  Power Button Replacement: 3 단계, 이미지 1/2 Panasonic Lumix DMC-ZS25  Power Button Replacement: 3 단계, 이미지 2/2
    • Use a spudger to detach the ribbon cable.
    • Be careful when you use the spudger because you do not want to break the the ribbon.
  4. Panasonic Lumix DMC-ZS25  Power Button Replacement: 4 단계, 이미지 1/3 Panasonic Lumix DMC-ZS25  Power Button Replacement: 4 단계, 이미지 2/3 Panasonic Lumix DMC-ZS25  Power Button Replacement: 4 단계, 이미지 3/3
    • Remove the button board using the plastic opening tool.
    • Remove the screen. Lift the screen from the right hand side.
    • After your hear a "click" sound, you have successfully opened the screen.
  5. Panasonic Lumix DMC-ZS25  Power Button Replacement: 5 단계, 이미지 1/2 Panasonic Lumix DMC-ZS25  Power Button Replacement: 5 단계, 이미지 2/2
    • Remove the two black screws that are located beneath the screen.
    • Lift the metal cover using the plastic opening tool.
  6. Panasonic Lumix DMC-ZS25  Power Button Replacement: 6 단계, 이미지 1/2 Panasonic Lumix DMC-ZS25  Power Button Replacement: 6 단계, 이미지 2/2
    • Use the plastic opener to remove the side covers.
  7. Panasonic Lumix DMC-ZS25  Power Button Replacement: 7 단계, 이미지 1/2 Panasonic Lumix DMC-ZS25  Power Button Replacement: 7 단계, 이미지 2/2
    • After removing the side covers, you will be able to take away the front cover with your hands.
    • Do not apply too much pressure on the outer cover of your device to avoid damage.
  8. Panasonic Lumix DMC-ZS25  Power Button Replacement: 8 단계, 이미지 1/1
    • To release the top cover of the camera, you need to open the 3.70 mm screw shown in the picture.
  9. Panasonic Lumix DMC-ZS25  Power Button Replacement: 9 단계, 이미지 1/1
    • Remove the top cover using the plastic opening tool.
  10. Panasonic Lumix DMC-ZS25  Power Button Replacement: 10 단계, 이미지 1/3 Panasonic Lumix DMC-ZS25  Power Button Replacement: 10 단계, 이미지 2/3 Panasonic Lumix DMC-ZS25  Power Button Replacement: 10 단계, 이미지 3/3
    • After removing the top cover of the camera, you will be able to easily remove the power button with your hand.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Abbas Khan
회원 가입일: 01/21/15
482 평판
안내서 4개 작성하였습니다
USF Tampa, Team 9-5, Brown Winter 2015 USF Tampa, Team 9-5, Brown Winter 2015 회원
USFT-BROWN-W15S9G5
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 570
