주요 콘텐츠로 건너뛰기
Panasonic Lumix DMC-ZS25 Flash Replacement
필요한 것
  1. Panasonic Lumix DMC-ZS25 Flash Replacement, Flash: 1 단계, 이미지 1/2 Panasonic Lumix DMC-ZS25 Flash Replacement, Flash: 1 단계, 이미지 2/2
    • Using a small screwdriver, remove the four 3.4mm screws from the right and left sides of your Panasonic Lumix Camera.
  2. Panasonic Lumix DMC-ZS25 Flash Replacement: 2 단계, 이미지 1/1
    • Using a small screwdriver, remove the two 2.6mm screws located next to the battery, on the outer casing.
  3. Panasonic Lumix DMC-ZS25 Flash Replacement: 3 단계, 이미지 1/1
    • Using the plastic opening tool, open the outer cover of your device.
    • The easiest way to open your device is by placing the tool in the HDMI port.
  4. Panasonic Lumix DMC-ZS25 Flash Replacement: 4 단계, 이미지 1/3 Panasonic Lumix DMC-ZS25 Flash Replacement: 4 단계, 이미지 2/3 Panasonic Lumix DMC-ZS25 Flash Replacement: 4 단계, 이미지 3/3
    • Using the spudger, pull upward on the screen cable to release it.
  5. Panasonic Lumix DMC-ZS25 Flash Replacement: 5 단계, 이미지 1/1
    • Using the plastic opening tool, lift the button board until it clicks.
  6. Panasonic Lumix DMC-ZS25 Flash Replacement: 6 단계, 이미지 1/2 Panasonic Lumix DMC-ZS25 Flash Replacement: 6 단계, 이미지 2/2
    • Using the plastic opening tool, lift the screen until it clicks.
  7. Panasonic Lumix DMC-ZS25 Flash Replacement: 7 단계, 이미지 1/1
    • Using a small screwdriver, remove the two 4.2mm screws located on the corner of the inner cover, under the screen.
  8. Panasonic Lumix DMC-ZS25 Flash Replacement: 8 단계, 이미지 1/1
    • Using the plastic opening tool, remove the inner cover.
  9. Panasonic Lumix DMC-ZS25 Flash Replacement: 9 단계, 이미지 1/2 Panasonic Lumix DMC-ZS25 Flash Replacement: 9 단계, 이미지 2/2
    • Using your hands or the opening tool, separate the device into two pieces, as shown.
  10. Panasonic Lumix DMC-ZS25 Flash Replacement: 10 단계, 이미지 1/2 Panasonic Lumix DMC-ZS25 Flash Replacement: 10 단계, 이미지 2/2
    • Using the spudger, remove the black side cover.
  11. Panasonic Lumix DMC-ZS25 Flash Replacement: 11 단계, 이미지 1/1
    • Using your hands, remove the front cover.
  12. Panasonic Lumix DMC-ZS25 Flash Replacement: 12 단계, 이미지 1/3 Panasonic Lumix DMC-ZS25 Flash Replacement: 12 단계, 이미지 2/3 Panasonic Lumix DMC-ZS25 Flash Replacement: 12 단계, 이미지 3/3
    • Using the spudger, unlock the screen cables from the circuit board.
    • Lift up the black clip to release the cables.
  13. Panasonic Lumix DMC-ZS25 Flash Replacement: 13 단계, 이미지 1/1
    • Using your hands, remove the lens.
  14. Panasonic Lumix DMC-ZS25 Flash Replacement: 14 단계, 이미지 1/1
    • Using the plastic opening tool, pull up on the edge of the circuit board until it clicks.
    • Remove the board.
  15. Panasonic Lumix DMC-ZS25 Flash Replacement: 15 단계, 이미지 1/1
    • Using a small screwdriver, remove the 3.7 mm screw near the green chip inside the camera, as shown. This will release the top of the camera.
  16. Panasonic Lumix DMC-ZS25 Flash Replacement: 16 단계, 이미지 1/3 Panasonic Lumix DMC-ZS25 Flash Replacement: 16 단계, 이미지 2/3 Panasonic Lumix DMC-ZS25 Flash Replacement: 16 단계, 이미지 3/3
    • Using the opening tool, pull up on the edge of the top cover to unlock it.
  17. Panasonic Lumix DMC-ZS25 Flash Replacement: 17 단계, 이미지 1/2 Panasonic Lumix DMC-ZS25 Flash Replacement: 17 단계, 이미지 2/2
    • Using the opening tool, remove the top board.
  18. Panasonic Lumix DMC-ZS25 Flash Replacement: 18 단계, 이미지 1/2 Panasonic Lumix DMC-ZS25 Flash Replacement: 18 단계, 이미지 2/2
    • Place the tip of the spudger at the edge of the top board, and work around three sides to loosen it.
    • Using the opening tool, lift up the top board. Now you will be able to safely remove the flash.
  19. Panasonic Lumix DMC-ZS25 Flash Replacement: 20 단계, 이미지 1/1
    • Remove the old flash, and put in the replacement.
결론
Abbas Khan
회원 가입일: 01/21/15
482 평판
안내서 4개 작성하였습니다
USF Tampa, Team 9-5, Brown Winter 2015 USF Tampa, Team 9-5, Brown Winter 2015 회원
USFT-BROWN-W15S9G5
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 8
전체 시간: 408
