주요 콘텐츠로 건너뛰기
Panasonic Lumix DMC-ZS3 Battery Replacement
필요한 것
  1. Panasonic Lumix DMC-ZS3 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Locate the small, hinged door on the bottom of the camera.
  2. Panasonic Lumix DMC-ZS3 Battery Replacement: 2 단계, 이미지 1/1
    • Using your fingernail or a spudger, push the small, grey switch on the hinged door from the left (locked) to the right (unlocked).
    • The hinged door should swing open after unlocking.
  3. Panasonic Lumix DMC-ZS3 Battery Replacement: 3 단계, 이미지 1/1
    • Using your fingernail or a spudger, push down on the small, grey tab holding the battery in place.
    • This should release the battery.
  4. Panasonic Lumix DMC-ZS3 Battery Replacement: 4 단계, 이미지 1/2 Panasonic Lumix DMC-ZS3 Battery Replacement: 4 단계, 이미지 2/2
    • Pull the battery out of the camera.
    • The battery should slide out easily.
결론
Juan Pablo Quinonez Weston
회원 가입일: 04/16/13
4 평판
안내서 4개 작성하였습니다
Cal Poly, Team 13-60, Johann Spring 2013 Cal Poly, Team 13-60, Johann Spring 2013 회원
CPSU-JOHANN-S13S13G60
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 10
30일 전: 23
전체 시간: 1,280
