주요 콘텐츠로 건너뛰기
Panasonic Lumix DMC-ZS3 Lens Replacement
필요한 것
  1. Panasonic Lumix DMC-ZS3 Lens Replacement, Back Cover: 1 단계, 이미지 1/3 Panasonic Lumix DMC-ZS3 Lens Replacement, Back Cover: 1 단계, 이미지 2/3 Panasonic Lumix DMC-ZS3 Lens Replacement, Back Cover: 1 단계, 이미지 3/3
    • Remove the following eleven screws securing the covers to the ZS3
    • Eleven 3 mm Phillips screws
    • Using too much pressure when removing the screws may strip the screws and complicate screw removal at a later time.
  2. Panasonic Lumix DMC-ZS3 Lens Replacement: 2 단계, 이미지 1/2 Panasonic Lumix DMC-ZS3 Lens Replacement: 2 단계, 이미지 2/2
    • Use the flat end of a spudger to pry apart the back cover from the rest of the unit as shown.
    • Be sure to carefully and slowly lift the back cover. Forcefully lifting the back cover and fully separating it at this point may ruin internal connections.
  3. Panasonic Lumix DMC-ZS3 Lens Replacement: 3 단계, 이미지 1/2 Panasonic Lumix DMC-ZS3 Lens Replacement: 3 단계, 이미지 2/2
    • Using your fingernail or a spudger, flip up the ZIF locking flap on the two LCD ribbon cable sockets that connect the back cover to the rest of the unit.
    • Be sure you are opening the locking tab, not pulling against the socket mounted to the board.
  4. Panasonic Lumix DMC-ZS3 Lens Replacement: 4 단계, 이미지 1/1
    • Remove the two LCD board ribbon cables out of their sockets.
  5. Panasonic Lumix DMC-ZS3 Lens Replacement, Lens: 5 단계, 이미지 1/1
    • Remove the three 3 mm black screws that surround the lens using a Phillips #00 screwdriver.
  6. Panasonic Lumix DMC-ZS3 Lens Replacement: 6 단계, 이미지 1/3 Panasonic Lumix DMC-ZS3 Lens Replacement: 6 단계, 이미지 2/3 Panasonic Lumix DMC-ZS3 Lens Replacement: 6 단계, 이미지 3/3
    • Flip up the locking flaps on the two LCD ribbon cable sockets with the spudger.
    • The LCD ribbon cables connect the back cover to the rest of the unit.
    • Use the spudger to disconnect the LCD ribbons.
  7. Panasonic Lumix DMC-ZS3 Lens Replacement: 7 단계, 이미지 1/3 Panasonic Lumix DMC-ZS3 Lens Replacement: 7 단계, 이미지 2/3 Panasonic Lumix DMC-ZS3 Lens Replacement: 7 단계, 이미지 3/3
    • Use your fingers or a spudger to gently remove the lens mechanism from the rest of the camera.
    • Excessive force may damage the camera. Be sure to lift the lens slowly and carefully to avoid damage to other parts.
    • Unlock lens mechanism located on the bottom of the device using your fingers.
결론
Kellen Ericson
회원 가입일: 04/17/13
18 평판
안내서 1개 작성함
Cal Poly, Team 13-60, Johann Spring 2013 Cal Poly, Team 13-60, Johann Spring 2013 회원
CPSU-JOHANN-S13S13G60
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 10
30일 전: 65
전체 시간: 3,265
