소개
If your Lumix has a damaged back casing, or if there is an issue with your internal components (such as your flash, lens, motherboard, LCD screen, and more), it’ll be necessary to either briefly remove or replace the Lumix’s back casing.
Before beginning, make sure to turn off your camera completely and remove its battery.
필요한 것
Remove the six 4mm screws located on the side and bottom of the camera casing using a Phillips #000 screwdriver.
거의 끝나갑니다!
결론
