주요 콘텐츠로 건너뛰기
Panasonic Lumix DMC-ZS35 Back Casing Replacement
필요한 것
  1. Panasonic Lumix DMC-ZS35 Back Casing Replacement, Back Casing: 1 단계, 이미지 1/3 Panasonic Lumix DMC-ZS35 Back Casing Replacement, Back Casing: 1 단계, 이미지 2/3 Panasonic Lumix DMC-ZS35 Back Casing Replacement, Back Casing: 1 단계, 이미지 3/3
    • Remove the six 4mm screws located on the side and bottom of the camera casing using a Phillips #000 screwdriver.
  2. Panasonic Lumix DMC-ZS35 Back Casing Replacement: 2 단계, 이미지 1/2 Panasonic Lumix DMC-ZS35 Back Casing Replacement: 2 단계, 이미지 2/2
    • Use a plastic opening tool to carefully separate the back casing from the main body of the camera. It's advised to run along the entire "seam" of the casing and the camera with the tool to ensure full separation.
  3. Panasonic Lumix DMC-ZS35 Back Casing Replacement: 3 단계, 이미지 1/1
    • Gently pry apart the back casing from the body of the camera. It's recommended to apply as minimal force as is necessary to prevent unintended damage to the camera or the casing.
결론
John Schug
회원 가입일: 02/04/20
97 평판
안내서 1개 작성함
UW Stout, Team S1-G2, Schneider-Bateman Spring 2020 UW Stout, Team S1-G2, Schneider-Bateman Spring 2020 회원
UWSTOUT-SCHNEIDER-BATEMAN-S20S1G2
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 143
