주요 콘텐츠로 건너뛰기
Panasonic Lumix DMC-ZS35 LCD Screen Replacement
필요한 것
  1. Panasonic Lumix DMC-ZS35 LCD Screen Replacement, Back Casing: 1 단계, 이미지 1/3 Panasonic Lumix DMC-ZS35 LCD Screen Replacement, Back Casing: 1 단계, 이미지 2/3 Panasonic Lumix DMC-ZS35 LCD Screen Replacement, Back Casing: 1 단계, 이미지 3/3
    • Remove the six 4mm screws located on the side and bottom of the camera casing using a Phillips #000 screwdriver.
  2. Panasonic Lumix DMC-ZS35 LCD Screen Replacement: 2 단계, 이미지 1/2 Panasonic Lumix DMC-ZS35 LCD Screen Replacement: 2 단계, 이미지 2/2
    • Use a plastic opening tool to carefully separate the back casing from the main body of the camera. It's advised to run along the entire "seam" of the casing and the camera with the tool to ensure full separation.
  3. Panasonic Lumix DMC-ZS35 LCD Screen Replacement: 3 단계, 이미지 1/1
    • Gently pry apart the back casing from the body of the camera. It's recommended to apply as minimal force as is necessary to prevent unintended damage to the camera or the casing.
  4. Panasonic Lumix DMC-ZS35 LCD Screen Replacement, Screen: 4 단계, 이미지 1/2 Panasonic Lumix DMC-ZS35 LCD Screen Replacement, Screen: 4 단계, 이미지 2/2
    • Unscrew the four 3mm screws holding the LCD screen hinge in place using a Phillips #000 screwdriver.
  5. Panasonic Lumix DMC-ZS35 LCD Screen Replacement: 5 단계, 이미지 1/1
    • Gently pull LCD screen ribbon cable from internal port to disconnect the screen and prevent unwanted damage.
    • Lift the freed LCD screen from the base camera to complete the process.
결론
Rachel Hughes
회원 가입일: 01/31/20
688 평판
안내서 4개 작성하였습니다
UW Stout, Team S1-G2, Schneider-Bateman Spring 2020 UW Stout, Team S1-G2, Schneider-Bateman Spring 2020 회원
UWSTOUT-SCHNEIDER-BATEMAN-S20S1G2
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 263
