주요 콘텐츠로 건너뛰기
Panasonic Lumix DMC-ZS40 Camera Sensor Replacement
필요한 것
  1. Panasonic Lumix DMC-ZS40 Camera Sensor Replacement, Battery: 1 단계, 이미지 1/2 Panasonic Lumix DMC-ZS40 Camera Sensor Replacement, Battery: 1 단계, 이미지 2/2
    • Find the battery/memory card door on the bottom right of the camera.
    • Use your finger or screw driver to slide the grey latch from the locked position to the open position. This will swing open the door.
  2. Panasonic Lumix DMC-ZS40 Camera Sensor Replacement: 2 단계, 이미지 1/1
    • Push up on the right-hand-side tab to release the battery.
  3. Panasonic Lumix DMC-ZS40 Camera Sensor Replacement: 3 단계, 이미지 1/2 Panasonic Lumix DMC-ZS40 Camera Sensor Replacement: 3 단계, 이미지 2/2
    • Remove battery from camera.
  4. Panasonic Lumix DMC-ZS40 Camera Sensor Replacement, Camera Sensor: 4 단계, 이미지 1/3 Panasonic Lumix DMC-ZS40 Camera Sensor Replacement, Camera Sensor: 4 단계, 이미지 2/3 Panasonic Lumix DMC-ZS40 Camera Sensor Replacement, Camera Sensor: 4 단계, 이미지 3/3
    • Unscrew these five 3mm screws located around the sides of the camera using a screw driver with a PH000 bit head.
  5. Panasonic Lumix DMC-ZS40 Camera Sensor Replacement: 5 단계, 이미지 1/2 Panasonic Lumix DMC-ZS40 Camera Sensor Replacement: 5 단계, 이미지 2/2
    • Pry off the back casing of the camera and place the camera face down.
  6. Panasonic Lumix DMC-ZS40 Camera Sensor Replacement: 6 단계, 이미지 1/1
    • Flip the right hand side control dial circuit board up.
  7. Panasonic Lumix DMC-ZS40 Camera Sensor Replacement: 7 단계, 이미지 1/3 Panasonic Lumix DMC-ZS40 Camera Sensor Replacement: 7 단계, 이미지 2/3 Panasonic Lumix DMC-ZS40 Camera Sensor Replacement: 7 단계, 이미지 3/3
    • Place the LCD screen to the side while you remove the plate cover. The LCD has already been removed in this picture. It is not necessary to remove the LCD screen or the control dial for this guide.
    • Remove these four 4mm screws and the 3mm screw on the top of the plate cover and on the side of the camera using a PH000 bit head. Once the screws are removed, the plate cover should lift right up.
    • Keep track of the different screw lengths and do not mix them up.
  8. Panasonic Lumix DMC-ZS40 Camera Sensor Replacement: 8 단계, 이미지 1/1
    • Remove the ribbon cable connecting the sensor to the motherboard. Use tweezers or a screw driver to lift up on the retaining flap of the ZIF connector to remove the cable.
  9. Panasonic Lumix DMC-ZS40 Camera Sensor Replacement: 9 단계, 이미지 1/1
    • Using the T3 Phillips Screwdriver, unscrew the three Torx T3 2.5mm screws holding the sensor down.
  10. Panasonic Lumix DMC-ZS40 Camera Sensor Replacement: 10 단계, 이미지 1/2 Panasonic Lumix DMC-ZS40 Camera Sensor Replacement: 10 단계, 이미지 2/2
    • Gently lift the sensor off of the springs.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Dean Favetta
회원 가입일: 02/14/17
340 평판
안내서 3개 작성하였습니다
USF Tampa, Team 20-3, Remmell Spring 2017 USF Tampa, Team 20-3, Remmell Spring 2017 회원
USFT-REMMELL-S17S20G3
3 회원들
안내서 10개 작성하였습니다
댓글 한 개
After the CCD is replaced, how do you adjust the 3 torx screws, so the ccd is in alignment? After the replacement the right side of my pictures are out of focus.
resufix888 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 7
전체 시간: 938
