주요 콘텐츠로 건너뛰기
Panasonic Lumix DMC-ZS40 LCD Screen Replacement
필요한 것
  1. Panasonic Lumix DMC-ZS40 LCD Screen Replacement, Battery: 1 단계, 이미지 2개 중 1개 Panasonic Lumix DMC-ZS40 LCD Screen Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Find the battery/memory card door on the bottom right of the camera.
    • Use your finger or screw driver to slide the grey latch from the locked position to the open position. This will swing open the door.
  2. Panasonic Lumix DMC-ZS40 LCD Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Push up on the right-hand-side tab to release the battery.
  3. Panasonic Lumix DMC-ZS40 LCD Screen Replacement: 3 단계, 이미지 2개 중 1개 Panasonic Lumix DMC-ZS40 LCD Screen Replacement: 3 단계, 이미지 2개 중 2개
    • Remove battery from camera.
  4. Panasonic Lumix DMC-ZS40 LCD Screen Replacement, LCD Screen: 4 단계, 이미지 3개 중 1개 Panasonic Lumix DMC-ZS40 LCD Screen Replacement, LCD Screen: 4 단계, 이미지 3개 중 2개 Panasonic Lumix DMC-ZS40 LCD Screen Replacement, LCD Screen: 4 단계, 이미지 3개 중 3개
    • Unscrew the five 3mm screws located around the sides of the camera using a PH000 bit or Phillips 000 Screwdriver.
  5. Panasonic Lumix DMC-ZS40 LCD Screen Replacement: 5 단계, 이미지 2개 중 1개 Panasonic Lumix DMC-ZS40 LCD Screen Replacement: 5 단계, 이미지 2개 중 2개
    • Pry off the back casing of the camera and place the camera face down.
  6. Panasonic Lumix DMC-ZS40 LCD Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Flip the right hand side control dial circuit board up.
  7. Panasonic Lumix DMC-ZS40 LCD Screen Replacement: 7 단계, 이미지 3개 중 1개 Panasonic Lumix DMC-ZS40 LCD Screen Replacement: 7 단계, 이미지 3개 중 2개 Panasonic Lumix DMC-ZS40 LCD Screen Replacement: 7 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Turn the LCD screen over to the side exposing the connection to the motherboard.
    • Remove the display data cable connecting the LCD screen to the motherboard. Using tweezers, pry up the black retaining flap then gently pull the display data cable free.
    • Be careful when handling any display data cables in the camera as they are prone to tearing.
    • To close for reassembly, slide the display data cable back into the ZIF connector and close the retaining flap.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Osayamen Orhue
회원 가입일: 02/14/17
174 평판
안내서 1개를 작성함
USF Tampa, Team 20-3, Remmell Spring 2017 USF Tampa, Team 20-3, Remmell Spring 2017 회원
USFT-REMMELL-S17S20G3
3 회원들
안내서 10개를 작성함
2가이드 댓글
The photo in step #7 is helpful but not sufficiently detailed to explain how the Panasonic ribbon connector works. Fortunately, Panasonic has a very detailed video about how these connectors work: https://www.youtube.com/watch?v=5-tBX1UN... (The helpful part of the video starts at 1:24)
It is recommended that you use a soft-tip instrument to flip the connector’s latching bar upward to release the ribbon cable. Then insert the ribbon cable from the replacement screen and carefully press the bar back down.
William Lee Roberts - 답글
Do you need a #0000 Phillips as stated in another video, or will a #000 Phillips work to remove the screws. Will a JIS #0000 or #000 work better being it is a Japan Product. Please advise, Thanks
Robert Myers - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 22
전체 시간: 2,288
