주요 콘텐츠로 건너뛰기
Panasonic Lumix DMC-ZS6 LCD Assembly Replacement
필요한 것
  1. Panasonic Lumix DMC-ZS6 LCD Assembly Replacement, LCD Assembly: 1 단계, 이미지 1/1
    • Remove the battery and SD card.
  2. Panasonic Lumix DMC-ZS6 LCD Assembly Replacement: 2 단계, 이미지 1/3 Panasonic Lumix DMC-ZS6 LCD Assembly Replacement: 2 단계, 이미지 2/3 Panasonic Lumix DMC-ZS6 LCD Assembly Replacement: 2 단계, 이미지 3/3
    • Unscrew the two bottom 1.0 mm screws with a Phillips #000 screwdriver.
    • Unscrew the two 1.0 mm screws to the left with a Phillips #000 screwdriver.
    • Unscrew the two 1.0 mm screws to the right with a Phillips #000 screwdriver.
  3. Panasonic Lumix DMC-ZS6 LCD Assembly Replacement: 3 단계, 이미지 1/1
    • Separate the back of the camera from the main body carefully.
    • Do not apply excessive force. The LCD is connected by ribbon cables that can be easily damaged.
  4. Panasonic Lumix DMC-ZS6 LCD Assembly Replacement: 4 단계, 이미지 1/2 Panasonic Lumix DMC-ZS6 LCD Assembly Replacement: 4 단계, 이미지 2/2
    • Use the tip of the spudger to flip up the black tabs on the ribbon cables.
    • Pull gently on the ribbon cables to unseat them.
  5. Panasonic Lumix DMC-ZS6 LCD Assembly Replacement: 5 단계, 이미지 1/1
    • Use the tip of the spudger to flip up the metal tabs.
    • Lift the LCD panel out of place carefully.
결론
Derrick Thompson
회원 가입일: 01/30/18
1,035 평판
안내서 5개 작성하였습니다
Baylor, Team S2-G5, Johnson Spring 2018 Baylor, Team S2-G5, Johnson Spring 2018 회원
BU-JOHNSON-S18S2G5
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 224
