주요 콘텐츠로 건너뛰기
Panasonic Lumix DMC-ZS6 SD Card Reader Replacement
필요한 것
  1. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement, SD Card Reader: 1 단계, 이미지 1개 중 1개
    • Remove the battery and the SD card.
  2. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 2 단계, 이미지 3개 중 1개 Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 2 단계, 이미지 3개 중 2개 Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 2 단계, 이미지 3개 중 3개
    • Unscrew the bottom two 1.0 mm screws with a Phillips #000 screwdriver.
    • Unscrew the two 1.0 mm screws on the right with a Phillips #000 screwdriver.
    • Unscrew the two 1.0 mm screws on the left with a Phillips #000 screwdriver.
  3. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 3 단계, 이미지 1개 중 1개
    • Carefully separate the back of the camera from the main body.
    • Do not apply excessive force. The LCD is connected by ribbon cables that can be easily damaged.
  4. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 4 단계, 이미지 2개 중 1개 Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 4 단계, 이미지 2개 중 2개
    • Use the tip of the spudger to flip up the black tabs on the ribbon cables.
    • Pull gently on the ribbon cables to unseat them.
  5. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 5 단계, 이미지 3개 중 1개 Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 5 단계, 이미지 3개 중 2개 Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 5 단계, 이미지 3개 중 3개
    • Unscrew the bottom 1.0 mm screw with a Phillips #000 screwdriver.
  6. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 6 단계, 이미지 1개 중 1개
    • Separate the front of the camera from the main body.
  7. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 7 단계, 이미지 2개 중 1개 Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 7 단계, 이미지 2개 중 2개
    • Use the tip of the spudger to disengage the plastic tab.
    • Carefully lift the selector switch away from the motherboard.
  8. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 8 단계, 이미지 2개 중 1개 Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 8 단계, 이미지 2개 중 2개
    • Unscrew the three silver 1.0 mm screws with a Phillips #000 screwdriver.
    • Use the tip of the spudger to disengage the metal tab.
    • Carefully lift the shield away from the motherboard.
  9. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 9 단계, 이미지 1개 중 1개
    • Insert the tip of the spudger into the center hole of the tripod mount.
    • Apply force in the direction facing away from the button.
    • Carefully lift the tripod mount out of the camera body.
  10. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 10 단계, 이미지 2개 중 1개 Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 10 단계, 이미지 2개 중 2개
    • Use the spudger to flip up the brown tab on the motherboard and carefully unseat the ribbon cable.
    • Insert the tip of the spudger into the hole on the daughterboard.
    • Apply upward force to remove the daughterboard from the main case.
  11. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 11 단계, 이미지 3개 중 1개 Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 11 단계, 이미지 3개 중 2개 Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 11 단계, 이미지 3개 중 3개
    • Use the spudger to flip up the two tabs on the motherboard and carefully unseat the ribbon cables.
    • Use the Phillips #000 screwdriver to remove the three 1.0 mm silver screws.
    • Carefully lift the lens assembly out of the camera.
  12. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 12 단계, 이미지 3개 중 1개 Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 12 단계, 이미지 3개 중 2개 Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 12 단계, 이미지 3개 중 3개
    • Use the tip of the spudger to disengage the tab on the back of the camera.
    • Use the tip of the spudger to disengage the two tabs on the front of the camera.
    • Carefully lift the top assembly out of place.
  13. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 13 단계, 이미지 2개 중 1개 Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 13 단계, 이미지 2개 중 2개
    • Use the spudger to disengage the two tabs.
    • Carefully lift the flash assembly out of place.
  14. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 14 단계, 이미지 3개 중 1개 Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 14 단계, 이미지 3개 중 2개 Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 14 단계, 이미지 3개 중 3개
    • Use the tip of the spudger to flip up the tab to unseat the ribbon cable.
    • Unscrew the two silver 1.0 mm screws with a Phillips #000.
    • Use the tip of the spudger to disengage the two plastic tabs, and carefully lift the motherboard out of place.
  15. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 15 단계, 이미지 2개 중 1개 Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 15 단계, 이미지 2개 중 2개
    • Unscrew the one silver 1.0 mm screw with a Phillips #000 screwdriver.
    • Use to tip of the spudger to disengage the plastic tab, then carefully lift the plastic shield out of place.
  16. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 16 단계, 이미지 1개 중 1개
    • Carefully lift the SD card reader assembly out of place.
결론
작성자
7다른 기여자 명과 함께
Derrick Thompson
회원 가입일: 01/30/18
1,035 평판
안내서 5개를 작성함
Baylor, Team S2-G5, Johnson Spring 2018 Baylor, Team S2-G5, Johnson Spring 2018 회원
BU-JOHNSON-S18S2G5
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 24
전체 시간: 1,599
