주요 콘텐츠로 건너뛰기
Panasonic Lumix DMC-ZS60 Camera Lens Replacement
필요한 것
  1. Panasonic Lumix DMC-ZS60 Camera Lens Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Use your finger to slide the black latch from the locked position to the open position on the memory card/battery door. This will open the door of the camera.
  2. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: 2 단계, 이미지 2개 중 1개 Panasonic Lumix DMC-ZS60 Camera Lens Replacement: 2 단계, 이미지 2개 중 2개
    • Push up the black tab on the right-hand-side to spring release the battery.
  3. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the battery by sliding it out from the camera.
  4. Panasonic Lumix DMC-ZS60 Camera Lens Replacement, LCD Screen: 4 단계, 이미지 3개 중 1개 Panasonic Lumix DMC-ZS60 Camera Lens Replacement, LCD Screen: 4 단계, 이미지 3개 중 2개 Panasonic Lumix DMC-ZS60 Camera Lens Replacement, LCD Screen: 4 단계, 이미지 3개 중 3개
    • Using the Phillips #000 Screwdriver, unscrew six 3mm screws. There are two screws located on three sides excluding the top.
  5. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: 5 단계, 이미지 1개 중 1개
    • Pry off back casing and set aside.
  6. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: 6 단계, 이미지 2개 중 1개 Panasonic Lumix DMC-ZS60 Camera Lens Replacement: 6 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Pull the right side control dial circuit board up.
    • Use tweezers to pry up the white retaining flap and gently pull the circuit board out.
  7. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: 7 단계, 이미지 3개 중 1개 Panasonic Lumix DMC-ZS60 Camera Lens Replacement: 7 단계, 이미지 3개 중 2개 Panasonic Lumix DMC-ZS60 Camera Lens Replacement: 7 단계, 이미지 3개 중 3개
    • Flip the LCD screen to the left.
    • Unscrew the two 3mm on the top right side using the Phillips #000 Screwdriver.
    • Lift the gray plate cover off.
  8. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: 8 단계, 이미지 2개 중 1개 Panasonic Lumix DMC-ZS60 Camera Lens Replacement: 8 단계, 이미지 2개 중 2개
    • Use tweezers to pry up the black retaining flat and gently pull to free the LCD screen from the device.
  9. Panasonic Lumix DMC-ZS60 Camera Lens Replacement, Motherboard: 9 단계, 이미지 1개 중 1개
    • Remove these three 3 mm screws with a Phillips #000 screwdriver.
  10. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: 10 단계, 이미지 3개 중 1개 Panasonic Lumix DMC-ZS60 Camera Lens Replacement: 10 단계, 이미지 3개 중 2개 Panasonic Lumix DMC-ZS60 Camera Lens Replacement: 10 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Disconnect these 9 ribbon cables from the motherboard. One ribbon cable is hidden underneath the larger one on the left.
    • Use tweezers to first lift up the retaining flaps for each connector, then pull out the ribbon cable.
  11. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: 11 단계, 이미지 2개 중 1개 Panasonic Lumix DMC-ZS60 Camera Lens Replacement: 11 단계, 이미지 2개 중 2개
    • Now you will able to lift the motherboard up and it will only be connected by two cables.
    • To fully remove the motherboard, you will have to solder the metal in order to remove the wires.
    • For more information on soldering, please visit the How to Solder and Desolder Connections guide.
  12. Panasonic Lumix DMC-ZS60 Camera Lens Replacement, Camera Lens: 12 단계, 이미지 2개 중 1개 Panasonic Lumix DMC-ZS60 Camera Lens Replacement, Camera Lens: 12 단계, 이미지 2개 중 2개
    • Unscrew the three 3mm screws attached to the plate cover using a Phillips #000 Screwdriver.
    • Pull off the plate cover to uncover the camera lens.
  13. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: 13 단계, 이미지 2개 중 1개 Panasonic Lumix DMC-ZS60 Camera Lens Replacement: 13 단계, 이미지 2개 중 2개
    • Lift the camera lens from the camera.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Jade Blackert
회원 가입일: 01/16/20
229 평판
안내서 2개를 작성함
댓글 한 개
A few years ago, I had a 30x zoom like this. It got a spot of dust inside the lens that showed up in photos, especially zoomed-in. I tried to unscrew the front of the lens to clean out the dust but the plastic broke, ruining the camera.
Fred Oswald - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 9
지난 30일: 34
전체 시간: 2,719
