주요 콘텐츠로 건너뛰기
Panasonic Lumix DMC-ZS60 LCD Screen Replacement
필요한 것
  1. Panasonic Lumix DMC-ZS60 LCD Screen Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Use your finger to slide the black latch from the locked position to the open position on the memory card/battery door. This will open the door of the camera.
  2. Panasonic Lumix DMC-ZS60 LCD Screen Replacement: 2 단계, 이미지 2개 중 1개 Panasonic Lumix DMC-ZS60 LCD Screen Replacement: 2 단계, 이미지 2개 중 2개
    • Push up the black tab on the right-hand-side to spring release the battery.
  3. Panasonic Lumix DMC-ZS60 LCD Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the battery by sliding it out from the camera.
  4. Panasonic Lumix DMC-ZS60 LCD Screen Replacement, LCD Screen: 4 단계, 이미지 3개 중 1개 Panasonic Lumix DMC-ZS60 LCD Screen Replacement, LCD Screen: 4 단계, 이미지 3개 중 2개 Panasonic Lumix DMC-ZS60 LCD Screen Replacement, LCD Screen: 4 단계, 이미지 3개 중 3개
    • Using the Phillips #000 Screwdriver, unscrew six 3mm screws. There are two screws located on three sides excluding the top.
  5. Panasonic Lumix DMC-ZS60 LCD Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Pry off back casing and set aside.
  6. Panasonic Lumix DMC-ZS60 LCD Screen Replacement: 6 단계, 이미지 2개 중 1개 Panasonic Lumix DMC-ZS60 LCD Screen Replacement: 6 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Pull the right side control dial circuit board up.
    • Use tweezers to pry up the white retaining flap and gently pull the circuit board out.
  7. Panasonic Lumix DMC-ZS60 LCD Screen Replacement: 7 단계, 이미지 3개 중 1개 Panasonic Lumix DMC-ZS60 LCD Screen Replacement: 7 단계, 이미지 3개 중 2개 Panasonic Lumix DMC-ZS60 LCD Screen Replacement: 7 단계, 이미지 3개 중 3개
    • Flip the LCD screen to the left.
    • Unscrew the two 3mm on the top right side using the Phillips #000 Screwdriver.
    • Lift the gray plate cover off.
  8. Panasonic Lumix DMC-ZS60 LCD Screen Replacement: 8 단계, 이미지 2개 중 1개 Panasonic Lumix DMC-ZS60 LCD Screen Replacement: 8 단계, 이미지 2개 중 2개
    • Use tweezers to pry up the black retaining flat and gently pull to free the LCD screen from the device.
결론
작성자
4다른 기여자 명과 함께
Audrey Arnold
회원 가입일: 01/16/20
353 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 25
전체 시간: 749
