주요 콘텐츠로 건너뛰기
Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement
필요한 것
  1. Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement, Mounting Bracket: 1 단계, 이미지 1/3 Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement, Mounting Bracket: 1 단계, 이미지 2/3 Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement, Mounting Bracket: 1 단계, 이미지 3/3
    • Remove the side panels by unscrewing the Phillips head screws on both sides of the camera.
  2. Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: 2 단계, 이미지 1/3 Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: 2 단계, 이미지 2/3 Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: 2 단계, 이미지 3/3
    • Remove the back panel by unscrewing the two Phillips head screws on the bottom of the camera towards the back.
    • Lift the back panel from the camera and set it aside.
  3. Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: 3 단계, 이미지 1/3 Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: 3 단계, 이미지 2/3 Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: 3 단계, 이미지 3/3
    • Unscrew the Phillips head screw shown in the picture to remove the front panel.
    • Remove the front panel to expose the bracket at the bottom of the camera.
  4. Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: 4 단계, 이미지 1/3 Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: 4 단계, 이미지 2/3 Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: 4 단계, 이미지 3/3
    • Pry the right side of the bracket up to allow you to grab the bracket with tweezers.
    • Grab the bracket with tweezers and slide it toward the battery door to remove it from the frame of the camera.
결론
Trevor Meyers
회원 가입일: 03/03/15
356 평판
안내서 2개 작성하였습니다
Sam Houston State, Team 13-13, Blackburne Spring 2015 Sam Houston State, Team 13-13, Blackburne Spring 2015 회원
SHSU-BLACKBURNE-S15S13G13
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 296
