주요 콘텐츠로 건너뛰기
해당 분해도는 작업 중 입니다 – 최신 변경 사항을 보려면 주기적으로 다시 로드 하십시오!
  1. Panasonic Lumix GX80/85 Teardown, Panasonic Lumix GX80/85 Teardown: 1 단계, 이미지 1/3 Panasonic Lumix GX80/85 Teardown, Panasonic Lumix GX80/85 Teardown: 1 단계, 이미지 2/3 Panasonic Lumix GX80/85 Teardown, Panasonic Lumix GX80/85 Teardown: 1 단계, 이미지 3/3
    • I have dust particles underneath the sensor glass, so sensor swabs didn't help me. I will try to get inside and under the glass. Additionally the EVF is overbright after a drop and maybe can be rearranged in the process.
    • You can spot dust marks yourself best if you set the camera to the "A" mode at f/22 and take a picture of the sky
  2. Panasonic Lumix GX80/85 Teardown: 2 단계, 이미지 1/1
    • Start with these two screws. Remember screw sizes and position, there are many different lengths used!
  3. Panasonic Lumix GX80/85 Teardown: 3 단계, 이미지 1/3 Panasonic Lumix GX80/85 Teardown: 3 단계, 이미지 2/3 Panasonic Lumix GX80/85 Teardown: 3 단계, 이미지 3/3
    • remove the flash spring as shown and the four screws
  4. Panasonic Lumix GX80/85 Teardown: 4 단계, 이미지 1/1
    • Remove this screw
  5. Panasonic Lumix GX80/85 Teardown: 5 단계, 이미지 1/1
    • remove the bottom screws
  6. Panasonic Lumix GX80/85 Teardown: 6 단계, 이미지 1/2 Panasonic Lumix GX80/85 Teardown: 6 단계, 이미지 2/2
    • remove the backplate and remove the ribbon cables
  7. Panasonic Lumix GX80/85 Teardown: 7 단계, 이미지 1/1
    • remove the 3 screws
  8. Panasonic Lumix GX80/85 Teardown: 8 단계, 이미지 1/3 Panasonic Lumix GX80/85 Teardown: 8 단계, 이미지 2/3 Panasonic Lumix GX80/85 Teardown: 8 단계, 이미지 3/3
    • to remove the sensor more easily you can remove the top bar before
  9. Panasonic Lumix GX80/85 Teardown: 9 단계, 이미지 1/1
    • Flash E.Capacitor removal
  10. Panasonic Lumix GX80/85 Teardown: 10 단계, 이미지 1/2 Panasonic Lumix GX80/85 Teardown: 10 단계, 이미지 2/2
    • Remove the 3 screws to get the sensor cover glass off. Be Careful not to let them fall inside the housing. There are extremely strong magnets!
Andi
회원 가입일: 01/21/17
271 평판
안내서 1개 작성함
댓글 15개
Hello,
and what about Flange back adjustment? Did you solve it somehow?
Štěpán Karásek - 답글
Hi, what exactly do you mean? I managed to wipe the sensor clean, but correct reassembly is difficult. I might have missaligned the magnets holding the sensor and now the camera sometimes seems to focus very slow.
Andi -
How do you remove the top case unit or top bar?
Nigel - 답글
I need to access the SD card slot, as I am afraid something is stuck in the slot. The camera is giving messages “insert the card again”
vibishika - 답글
SD card is known as “delicate” one. Use MicroSD adapter with 2-3 plies of adhesive tape on “title side” over contacts. Plus two 5mm stripes near MicroSD slot. Insert adapter and use two stripes to secure your adapter to battery compartment walls. Never move adapter until you need to replace it. Then only use MicroSD cards with some adhesive tape stripe to pull the card from your new slot. Once properly contacted, adapter will avoid “insert SD card back” message on screen.
c64club - 답글
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 19
30일 전: 78
전체 시간: 5,396
