주요 콘텐츠로 건너뛰기
Panasonic Lumix ZS50 Battery Replacement
필요한 것
  1. Panasonic Lumix ZS50 Battery Replacement, Battery: 1 단계, 이미지 1/2 Panasonic Lumix ZS50 Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Turn the camera off and identify the battery door located on the bottom of the camera.
  2. Panasonic Lumix ZS50 Battery Replacement: 2 단계, 이미지 1/2 Panasonic Lumix ZS50 Battery Replacement: 2 단계, 이미지 2/2
    • Slide the "open" latch to the left: the battery door should spring open.
    • If your battery door doesn't open you may have to pry it open using a plastic opening tool or a standard spudger.
  3. Panasonic Lumix ZS50 Battery Replacement: 3 단계, 이미지 1/1
    • To release the battery, slide the white release lever next to the SD card slot.
    • If you find the battery release lever to be jammed you can push it using a plastic opening tool or standard spudger.
  4. Panasonic Lumix ZS50 Battery Replacement: 4 단계, 이미지 1/1
    • The battery should now be released; you may now remove the battery from the camera body.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Cameron Voos
회원 가입일: 02/01/17
32 평판
안내서 1개 작성함
Baylor, Team 8-5, Whitney Spring 2017 Baylor, Team 8-5, Whitney Spring 2017 회원
BU-WHITNEY-S17S8G5
3 회원들
안내서 4개 작성하였습니다
댓글 한 개
Repair guide is very clear and well-done
BayleeVersteeg - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 15
전체 시간: 486
