주요 콘텐츠로 건너뛰기
Panasonic Lumix ZS50 Lens Assembly Replacement
필요한 것
  1. Panasonic Lumix ZS50 Lens Assembly Replacement, Battery: 1 단계, 이미지 1/2 Panasonic Lumix ZS50 Lens Assembly Replacement, Battery: 1 단계, 이미지 2/2
    • Turn the camera off and identify the battery door located on the bottom of the camera.
  2. Panasonic Lumix ZS50 Lens Assembly Replacement: 2 단계, 이미지 1/2 Panasonic Lumix ZS50 Lens Assembly Replacement: 2 단계, 이미지 2/2
    • Slide the "open" latch to the left: the battery door should spring open.
    • If your battery door doesn't open you may have to pry it open using a plastic opening tool or a standard spudger.
  3. Panasonic Lumix ZS50 Lens Assembly Replacement: 3 단계, 이미지 1/1
    • To release the battery, slide the white release lever next to the SD card slot.
    • If you find the battery release lever to be jammed you can push it using a plastic opening tool or standard spudger.
  4. Panasonic Lumix ZS50 Lens Assembly Replacement: 4 단계, 이미지 1/1
    • The battery should now be released; you may now remove the battery from the camera body.
  5. Panasonic Lumix ZS50 Lens Assembly Replacement, LCD Screen: 5 단계, 이미지 1/3 Panasonic Lumix ZS50 Lens Assembly Replacement, LCD Screen: 5 단계, 이미지 2/3 Panasonic Lumix ZS50 Lens Assembly Replacement, LCD Screen: 5 단계, 이미지 3/3
    • Orient the camera so the bottom is facing up and the battery door is on the right side.
    • Remove four black screws from the bottom of the camera.
    • Remove two black screws from the right side of the camera.
    • Remove one black screw from the left side of the camera.
  6. Panasonic Lumix ZS50 Lens Assembly Replacement: 6 단계, 이미지 1/2 Panasonic Lumix ZS50 Lens Assembly Replacement: 6 단계, 이미지 2/2
    • Remove the casing from the camera by hand or using a plastic opening tool.
  7. Panasonic Lumix ZS50 Lens Assembly Replacement: 7 단계, 이미지 1/2 Panasonic Lumix ZS50 Lens Assembly Replacement: 7 단계, 이미지 2/2
    • Use a spudger to lift up and tug off the green button board.
    • Be careful to not damage the attached ribbon cable.
  8. Panasonic Lumix ZS50 Lens Assembly Replacement: 8 단계, 이미지 1/3 Panasonic Lumix ZS50 Lens Assembly Replacement: 8 단계, 이미지 2/3 Panasonic Lumix ZS50 Lens Assembly Replacement: 8 단계, 이미지 3/3
    • Remove the screen using the plastic opening tool, prying from the top.
    • Once it's lifted up, tug lightly on the large ribbon cable to detach the screen from the camera body.
  9. Panasonic Lumix ZS50 Lens Assembly Replacement, Lens Assembly: 9 단계, 이미지 1/3 Panasonic Lumix ZS50 Lens Assembly Replacement, Lens Assembly: 9 단계, 이미지 2/3 Panasonic Lumix ZS50 Lens Assembly Replacement, Lens Assembly: 9 단계, 이미지 3/3
    • Remove the three screws from the center of the copper plate.
    • Remove the four screws from the outer edges of the copper plate.
    • Use a plastic or metal spudger to pry the copper plate out of place.
  10. Panasonic Lumix ZS50 Lens Assembly Replacement: 10 단계, 이미지 1/2 Panasonic Lumix ZS50 Lens Assembly Replacement: 10 단계, 이미지 2/2
    • Remove the casing from the circuitboard by hand.
    • Remove the HDMI port casing by hand.
  11. Panasonic Lumix ZS50 Lens Assembly Replacement: 11 단계, 이미지 1/3 Panasonic Lumix ZS50 Lens Assembly Replacement: 11 단계, 이미지 2/3 Panasonic Lumix ZS50 Lens Assembly Replacement: 11 단계, 이미지 3/3
    • Disconnect all orange ribbon cables connecting to the circuitboard by hand.
    • Disconnect the circuitboard by hand.
    • There will be one orange ribbon cable attached to the top that can now be removed.
  12. Panasonic Lumix ZS50 Lens Assembly Replacement: 12 단계, 이미지 1/3 Panasonic Lumix ZS50 Lens Assembly Replacement: 12 단계, 이미지 2/3 Panasonic Lumix ZS50 Lens Assembly Replacement: 12 단계, 이미지 3/3
    • Remove the seven screws surrounding the lens assembly.
    • Move all ribbon cables out of your way while unscrewing.
    • Remove the three springs surrounding the lens.
    • Apply pressure on the front of the lens to push the lens out.
결론
Bridget Lathrop
회원 가입일: 02/01/17
149 평판
안내서 2개 작성하였습니다
Baylor, Team 8-5, Whitney Spring 2017 Baylor, Team 8-5, Whitney Spring 2017 회원
BU-WHITNEY-S17S8G5
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 42
전체 시간: 1,067
