주요 콘텐츠로 건너뛰기
Panasonic Lumx DMC-ZS19 LCD Screen Replacement
필요한 것
  1. Panasonic Lumx DMC-ZS19 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 1/3 Panasonic Lumx DMC-ZS19 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 2/3 Panasonic Lumx DMC-ZS19 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 3/3
    • Locate the pair (2) of screws on each side of the camera and remove them. Then locate the pair (2) of screws on the bottom of the camera, located on each side of the tripod screw-in area, and remove them.
  2. Panasonic Lumx DMC-ZS19 LCD Screen Replacement: 2 단계, 이미지 1/1
    • Using the plastic prying tool, remove the cover of the camera that is on the same side as your LCD screen. This cover should come off relatively easily, and will expose the motherboard that the screen is connected to.
  3. Panasonic Lumx DMC-ZS19 LCD Screen Replacement: 3 단계, 이미지 1/1
    • Disconnect the motherboard that the LCD screen is connected to from the main motherboard.
  4. Panasonic Lumx DMC-ZS19 LCD Screen Replacement: 4 단계, 이미지 1/1
    • Using your hand, follow the two data-strips that connect the LCD screen to the motherboard and unclip them. Once the data-strips are unclipped, remove them from the motherboard and the screen will be free.
결론
Patrick Thoennissen
회원 가입일: 09/14/15
494 평판
안내서 4개 작성하였습니다
USF Tampa, Team 14-1, Meier Fall 2015 USF Tampa, Team 14-1, Meier Fall 2015 회원
USFT-MEIER-F15S14G1
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 11
전체 시간: 299
