주요 콘텐츠로 건너뛰기
Panasonic Lumx DMC-ZS19 Motherboard Replacement
필요한 것
  1. Panasonic Lumx DMC-ZS19 Motherboard Replacement, LCD Screen: 1 단계, 이미지 1/3 Panasonic Lumx DMC-ZS19 Motherboard Replacement, LCD Screen: 1 단계, 이미지 2/3 Panasonic Lumx DMC-ZS19 Motherboard Replacement, LCD Screen: 1 단계, 이미지 3/3
    • Locate the pair (2) of screws on each side of the camera and remove them. Then locate the pair (2) of screws on the bottom of the camera, located on each side of the tripod screw-in area, and remove them.
  2. Panasonic Lumx DMC-ZS19 Motherboard Replacement: 2 단계, 이미지 1/1
    • Using the plastic prying tool, remove the cover of the camera that is on the same side as your LCD screen. This cover should come off relatively easily, and will expose the motherboard that the screen is connected to.
  3. Panasonic Lumx DMC-ZS19 Motherboard Replacement: 3 단계, 이미지 1/1
    • Disconnect the motherboard that the LCD screen is connected to from the main motherboard.
  4. Panasonic Lumx DMC-ZS19 Motherboard Replacement: 4 단계, 이미지 1/1
    • Using your hand, follow the two data-strips that connect the LCD screen to the motherboard and unclip them. Once the data-strips are unclipped, remove them from the motherboard and the screen will be free.
  5. Panasonic Lumx DMC-ZS19 Motherboard Replacement, Lens: 5 단계, 이미지 1/2 Panasonic Lumx DMC-ZS19 Motherboard Replacement, Lens: 5 단계, 이미지 2/2
    • After the screen has been removed, the main motherboard is directly underneath it. There is a bronze, metal separation piece that separates the main motherboard from the one connected to the lens. This metal piece is held in with 3 screws. Remove these 3 screws and the metal piece will be free.
  6. Panasonic Lumx DMC-ZS19 Motherboard Replacement: 6 단계, 이미지 1/1
    • Once the bronze metal plate is removed, the main motherboard will be exposed. There is a plastic riser (it looks like a lowercase "b" on the right side of the camera) that separates the metal plate from the motherboard. Remove this plastic riser.
  7. Panasonic Lumx DMC-ZS19 Motherboard Replacement: 7 단계, 이미지 1/3 Panasonic Lumx DMC-ZS19 Motherboard Replacement: 7 단계, 이미지 2/3 Panasonic Lumx DMC-ZS19 Motherboard Replacement: 7 단계, 이미지 3/3
    • Once the plastic riser is removed, it is time to remove the lens. To do this, simply follow the data strips (2) that connect the lens to the main motherboard and unclip them by turning the black bar into a position that is perpendicular to the motherboard. Once these clips are open, the data strips and the lens should simply slide out.
  8. Panasonic Lumx DMC-ZS19 Motherboard Replacement, Motherboard: 8 단계, 이미지 1/1
    • After the lens has been removed, there is only one screw that holds the main motherboard in place. Remove this screw, located on the right side of the motherboard, and remove it.
  9. Panasonic Lumx DMC-ZS19 Motherboard Replacement: 9 단계, 이미지 1/3 Panasonic Lumx DMC-ZS19 Motherboard Replacement: 9 단계, 이미지 2/3 Panasonic Lumx DMC-ZS19 Motherboard Replacement: 9 단계, 이미지 3/3
    • Once the screw has been removed, the motherboard should pop right out. If you're having difficulties, use the plastic prying tool.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Patrick Thoennissen
회원 가입일: 09/14/15
494 평판
안내서 4개 작성하였습니다
USF Tampa, Team 14-1, Meier Fall 2015 USF Tampa, Team 14-1, Meier Fall 2015 회원
USFT-MEIER-F15S14G1
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 461
