주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
소개
How to fix squeaky water flow
부품
지정된 부품이 없습니다.
  1. Warning: Bevore working at it unplug the power. Here you can see the plastic tube from where the water comes out. it is clipped in a clear plastic shape. Open the clips and pull Shake it a litlle so the tube can get out here.
    • Warning: Bevore working at it unplug the power. Here you can see the plastic tube from where the water comes out. it is clipped in a clear plastic shape. Open the clips and pull
    • Shake it a litlle so the tube can get out here.
    • This clear plastic is fragile,
    • be careful with it or the clipse may break.
  2. More pictures, look. you can clean it with citric acid. you can clean it with citric acid.
    • More pictures, look.
    • you can clean it with citric acid.
  3. Nintendo Switch 수리 키트
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. How to open. First remove two PH2 screws left and right. PULL the complete display. Shake it a little because the flap of the ice-crusher could be frosted. Now pull it downwards. Now turn around and you see the plastic from the lever.
    • How to open. First remove two PH2 screws left and right.
    • PULL the complete display. Shake it a little because the flap of the ice-crusher could be frosted.
    • Now pull it downwards. Now turn around and you see the plastic from the lever.
  5. This is the backside: The quadratic black rubber part is a motorized flap of the ice-crusher, be careful with it, there are fragile springs, dont loose them.
    • This is the backside: The quadratic black rubber part is a motorized flap of the ice-crusher, be careful with it, there are fragile springs, dont loose them.
    • Now spray some SILICONE_SPRAY on the moving parts, i made some red circles for it. Just a little bit, also on the springs.
    • TRY, move it, now the noise should gone, whiole moving it.
    • Thats it, reassemble it, be careful with the notches and clipse.
    • done. :)
결론
easy
다른 2명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
Schwarzstein님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
Schwarzstein
회원 가입일: 2013년 07월 15일
2,409 평판
안내서 14개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 21
전체 시간: 771
