소개
A guide to removing the lens assembly on the camcorder.
필요한 것
Locate the blue plastic tool opener, then remove both the round record/playback and record/power control knobs by prying it open from the camcorder.
Place a plastic opening tool under the bottom of the blue panel beneath the camcorder.
Using two tools may be useful, if difficult.
Move the plastic opening tool up the side of the camcorder as shown. Carefully separate the LCD panel from the rest of the camcorder.
Remove the panel from the camcorder.
Using #00 phillips screwdriver, remove two 4.5mm black screws holding lens in place.
다른 한 분이 해당 안내서를 완성하였습니다.
