소개
In order to repair the problems that may arise while using the Panasonic PV-GS9 you must disassemble the camcorder entirely. This will allow you to have three large pieces of the camcorder from which all the repairs can be made.
도구
부품
부품은 필요하지 않습니다.
Using a plastic opening tool, remove the record/playback and record/power control knobs from the camcorder.
Rotate the camcorder so that the tape compartment is facing you. Remove the single 4.5mm black screw, which is above the hook for the hand strap.
It may help you during this step to undo the strap on one end.
Next, rotate the camcorder so that the lens is facing you. Remove the single 4.5mm black screw from the front panel.
다른 한 분이 해당 안내서를 완성하였습니다.
