주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Panasonic RF-1101 Radio Disassembly
필요한 것
  1. Panasonic RF-1101 Radio Disassembly, Radio: 1 단계, 이미지 3개 중 1개 Panasonic RF-1101 Radio Disassembly, Radio: 1 단계, 이미지 3개 중 2개 Panasonic RF-1101 Radio Disassembly, Radio: 1 단계, 이미지 3개 중 3개
    • Lets fix the sliders and turn knobs with Deoxit
  2. Panasonic RF-1101 Radio Disassembly: 2 단계, 이미지 1개 중 1개
    • 5 Screws Removed from the BAck
  3. Panasonic RF-1101 Radio Disassembly, Unhook the Antenna Connector ont he right side.: 3 단계, 이미지 3개 중 1개 Panasonic RF-1101 Radio Disassembly, Unhook the Antenna Connector ont he right side.: 3 단계, 이미지 3개 중 2개 Panasonic RF-1101 Radio Disassembly, Unhook the Antenna Connector ont he right side.: 3 단계, 이미지 3개 중 3개
    • Wire on the right is the Antenna Wire. It Attaches to the board by a connector. Unhook it so the back will lay over.
  4. Panasonic RF-1101 Radio Disassembly, Transformer and Battery connector: 4 단계, 이미지 2개 중 1개 Panasonic RF-1101 Radio Disassembly, Transformer and Battery connector: 4 단계, 이미지 2개 중 2개
    • The transformer for AC and the Battery connector for DC
  5. Panasonic RF-1101 Radio Disassembly, Board View: 5 단계, 이미지 3개 중 1개 Panasonic RF-1101 Radio Disassembly, Board View: 5 단계, 이미지 3개 중 2개 Panasonic RF-1101 Radio Disassembly, Board View: 5 단계, 이미지 3개 중 3개
    • Board view of top and bottom of board. Remove 3 screws to take thew board out. Remember the one screw with washer in the left top. Also note the position of the screws as the screws in the back also go through the board.
  6. Panasonic RF-1101 Radio Disassembly, Battery or AC selector: 6 단계, 이미지 3개 중 1개 Panasonic RF-1101 Radio Disassembly, Battery or AC selector: 6 단계, 이미지 3개 중 2개 Panasonic RF-1101 Radio Disassembly, Battery or AC selector: 6 단계, 이미지 3개 중 3개
    • The battery, off and AC selector runs through the front on to the back of the unit. Use Deoxit ont he slider in the front and the unit to the back of board. in 3 places. As shown
  7. Panasonic RF-1101 Radio Disassembly, Tunner Knob: 7 단계, 이미지 3개 중 1개 Panasonic RF-1101 Radio Disassembly, Tunner Knob: 7 단계, 이미지 3개 중 2개 Panasonic RF-1101 Radio Disassembly, Tunner Knob: 7 단계, 이미지 3개 중 3개
    • Using Deoxit to clean and lubricate the tuning knob to clear up static and crackling.
  8. Panasonic RF-1101 Radio Disassembly, Tunning Knob and volume: 8 단계, 이미지 3개 중 1개 Panasonic RF-1101 Radio Disassembly, Tunning Knob and volume: 8 단계, 이미지 3개 중 2개 Panasonic RF-1101 Radio Disassembly, Tunning Knob and volume: 8 단계, 이미지 3개 중 3개
    • The Tuning knob pulls off front and the tuning mechanism unscrews with the nut. Deoxit clears up the crackling on the volume slider as well.
  9. Panasonic RF-1101 Radio Disassembly, Speaker Ohms and Numbers: 9 단계, 이미지 3개 중 1개 Panasonic RF-1101 Radio Disassembly, Speaker Ohms and Numbers: 9 단계, 이미지 3개 중 2개 Panasonic RF-1101 Radio Disassembly, Speaker Ohms and Numbers: 9 단계, 이미지 3개 중 3개
    • Speaker is 8 Ohm and the numbers found on the board and the back of unit.
결론
작성자
2다른 기여자 명과 함께
T Bone
회원 가입일: 03/11/21
169 평판
안내서 1개를 작성함
T-Bone Electronics T-Bone Electronics 회원
Business
1 회원
안내서 1개 작성
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 41
전체 시간: 538
