소개
In this guide, you will learn how to replace the band that runs the 3-digit cassette counter on this device. If you find that the counter is not running while cassettes are being played, it is quite possible that the small rubber band has become worn out from frequent use. This guide will show you what you need to do to to get your device counting again.
필요한 것
Remove the three screws from the back of the device body.
Remove both of the screws from the battery compartment.
Remove the back of the device.
Make sure not to pull apart the cords that hold the device together.
다른 2명이 해당 안내서를 완성하였습니다.
