주요 콘텐츠로 건너뛰기
소개
In this guide, you will learn how to replace the band that runs the 3-digit cassette counter on this device. If you find that the counter is not running while cassettes are being played, it is quite possible that the small rubber band has become worn out from frequent use. This guide will show you what you need to do to to get your device counting again.
부품
지정된 부품이 없습니다.
  1. Remove the three screws from the back of the device body. Remove both of the screws from the battery compartment. Remove the back of the device.
    • Remove the three screws from the back of the device body.
    • Remove both of the screws from the battery compartment.
    • Remove the back of the device.
    • Make sure not to pull apart the cords that hold the device together.
  2. Carefully remove the band from the gear spindle. Dispose of the old, broken band. Dispose of the old, broken band.
    • Carefully remove the band from the gear spindle.
    • Dispose of the old, broken band.
  3. Insert the new band into the gear spindle. Twist the black spindle to make sure the counter works. If the counter does not work, ensure the band is not broken due to installation.
    • Insert the new band into the gear spindle.
    • Twist the black spindle to make sure the counter works.
    • If the counter does not work, ensure the band is not broken due to installation.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Dmitriy Borisyuk
회원 가입일: 2015년 04월 07일
237 평판
안내서 2개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 585
