주요 콘텐츠로 건너뛰기
Panasonic RQ-2102 Buttons Replacement
필요한 것
  1. Panasonic RQ-2102 Buttons Replacement, Buttons: 1 단계, 이미지 1/3 Panasonic RQ-2102 Buttons Replacement, Buttons: 1 단계, 이미지 2/3 Panasonic RQ-2102 Buttons Replacement, Buttons: 1 단계, 이미지 3/3
    • Remove the three screws from the back of the device body.
    • Remove both screws from battery compartment.
    • Remove the back.
    • Make sure not to pull apart the cords that connect the device.
  2. Panasonic RQ-2102 Buttons Replacement: 2 단계, 이미지 1/3 Panasonic RQ-2102 Buttons Replacement: 2 단계, 이미지 2/3 Panasonic RQ-2102 Buttons Replacement: 2 단계, 이미지 3/3
    • Remove screws from the sides of the silver button pin roller.
    • Pry out the silver bar
    • Remove the desired button
  3. Panasonic RQ-2102 Buttons Replacement: 3 단계, 이미지 1/3 Panasonic RQ-2102 Buttons Replacement: 3 단계, 이미지 2/3 Panasonic RQ-2102 Buttons Replacement: 3 단계, 이미지 3/3
    • Insert the new button in place of the old button.
    • Put the silver pin roller back into its place over the buttons.
    • Put screws back into their original places by the sides of the silver pin roller.
    • If new buttons are not available, clean old buttons with a wet rag.
    • If the buttons do not work, ensure they are in their correct positions.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Dmitriy Borisyuk
회원 가입일: 04/07/15
237 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 795
