주요 콘텐츠로 건너뛰기
Panasonic RQ-2102 Cassette Holder Spring Replacement
필요한 것
  1. Panasonic RQ-2102 Cassette Holder Spring Replacement, Cassette Holder Spring: 1 단계, 이미지 1/3 Panasonic RQ-2102 Cassette Holder Spring Replacement, Cassette Holder Spring: 1 단계, 이미지 2/3 Panasonic RQ-2102 Cassette Holder Spring Replacement, Cassette Holder Spring: 1 단계, 이미지 3/3
    • Remove the three screws from the back of the device body.
    • Remove both screws from the battery compartment.
    • Remove the back of the device.
    • All screws in the body of this device are the same size.
    • When pulling apart the device, both sides are connected by a cord that could be damaged if care is not taken.
  2. Panasonic RQ-2102 Cassette Holder Spring Replacement: 2 단계, 이미지 1/3 Panasonic RQ-2102 Cassette Holder Spring Replacement: 2 단계, 이미지 2/3 Panasonic RQ-2102 Cassette Holder Spring Replacement: 2 단계, 이미지 3/3
    • Make sure the brass colored spring by the cassette door is in the correct position.
    • Remove the screw that holds the spring if broken.
    • Remove the spring from the device.
  3. Panasonic RQ-2102 Cassette Holder Spring Replacement: 3 단계, 이미지 1/2 Panasonic RQ-2102 Cassette Holder Spring Replacement: 3 단계, 이미지 2/2
    • Replace the old spring with the new spring, making sure that it is installed in the correct position.
    • Insert the screw back into position, ensuring that it holds the spring.
    • If the spring is loose, tighten the screw.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Andrew Campbell
회원 가입일: 04/07/15
276 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 983
