소개
In this guide, you will learn how to replace the holding handle. Because the handle is a thin plastic piece, after heavy use it is more likely to break. If the handle is actually broken, then replacing it is easy. However if the two handle catches, which holds the handle in place, are broken then the entire body needs to be replaced due to them being molded to the body.
도구
부품
지정된 부품이 없습니다.
Remove the three M5-0.8 x 12 mm Phillips #0 screws from the back of the device body
Remove two more screws from inside the battery compartment
다른 2명이 해당 안내서를 완성하였습니다.
