도구
부품
지정된 부품이 없습니다.
With the front display of the device facing you, rotate the device 90 degrees counter clockwise.
Now rotate the device 180 degrees and remove the second screw.
Remove the screw that is on the right side of the panel facing you.
Remove all screws with a phillips head screwdriver.
거의 끝나갑니다!
결론
다른 2명이 해당 안내서를 완성하였습니다.
