주요 콘텐츠로 건너뛰기
Panasonic SA-HT810V VHS Drive Replacement
필요한 것
  1. Panasonic SA-HT810V VHS Drive Replacement, VHS Drive: 1 단계, 이미지 1/3 Panasonic SA-HT810V VHS Drive Replacement, VHS Drive: 1 단계, 이미지 2/3 Panasonic SA-HT810V VHS Drive Replacement, VHS Drive: 1 단계, 이미지 3/3
    • With the front display of the device facing you, rotate the device 90 degrees counter clockwise.
    • Now rotate the device 180 degrees and remove the second screw.
    • Remove the screw that is on the right side of the panel facing you.
    • All screws will need to be removed with a phillips head screwdriver.
  2. Panasonic SA-HT810V VHS Drive Replacement: 2 단계, 이미지 1/2 Panasonic SA-HT810V VHS Drive Replacement: 2 단계, 이미지 2/2
    • Rotate the device so that the back faces you.
    • With a phillips heat screwdriver, locate and remove the four screws highlighted by the red circles in image one.
  3. Panasonic SA-HT810V VHS Drive Replacement: 3 단계, 이미지 1/1
    • Before removing cover make sure that the back of the device is facing you.
    • Remove the top cover by bending out on the sides, and pulling the cover towards you while applying upward pressure.
  4. Panasonic SA-HT810V VHS Drive Replacement: 4 단계, 이미지 1/3 Panasonic SA-HT810V VHS Drive Replacement: 4 단계, 이미지 2/3 Panasonic SA-HT810V VHS Drive Replacement: 4 단계, 이미지 3/3
    • Pull up the two tabs on top
    • Pull the the three tabs on the side there is one on the left and two and the right side of the device when it is facing you.
    • Depress the four tabs on the bottom of the device.
  5. Panasonic SA-HT810V VHS Drive Replacement: 5 단계, 이미지 1/1
    • Carefully pull off the front panel of the device.
    • The front is attached to the device with cables so be careful when removing.
  6. Panasonic SA-HT810V VHS Drive Replacement: 6 단계, 이미지 1/2 Panasonic SA-HT810V VHS Drive Replacement: 6 단계, 이미지 2/2
    • With the device front facing you remove the six screws with a phillips head screwdriver around the VHS drive.
  7. Panasonic SA-HT810V VHS Drive Replacement: 7 단계, 이미지 1/1
    • Remove the three cables attaching the VHS to the Mother Board.
    • Carefully pull the VHS drive out of the device and follow the steps in reverse to place the new one in.
결론
Nathan Cheadle
회원 가입일: 04/15/10
161 평판
안내서 7개 작성하였습니다
Cal Poly, Team 16-5, Maness Spring 2010 Cal Poly, Team 16-5, Maness Spring 2010 회원
CPSU-MANESS-S10S16G5
4 회원들
안내서 7개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 960
