이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
With the front display of the device facing you, rotate the device 90 degrees counter clockwise.
Now rotate the device 180 degrees and remove the second screw.
Remove the screw that is on the right side of the panel facing you.
All screws will need to be removed with a phillips head screwdriver.
Rotate the device so that the back faces you.
With a phillips heat screwdriver, locate and remove the four screws highlighted by the red circles in image one.
Before removing cover make sure that the back of the device is facing you.
Remove the top cover by bending out on the sides, and pulling the cover towards you while applying upward pressure.
Pull up the two tabs on top
Pull the the three tabs on the side there is one on the left and two and the right side of the device when it is facing you.
Depress the four tabs on the bottom of the device.
With the device front facing you remove the six screws with a phillips head screwdriver around the VHS drive.
Remove the three cables attaching the VHS to the Mother Board.
Make sure the cables connecting the VHS Drive are fully inserted before powering the machine on to prevent damage to the internal components.
