소개
This repair guide will show you how to replace the tape player unit of your Panasonic SA-PM17 by tearing down the device to the point where you can take the unit out and put a new one in.
필요한 것
With a Phillips #0 screwdriver, remove the eight 9.5mm screws attached to the left and right panels of the device.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 2개
The problem with my micro system pm17 is that the tape drive's head does not work. I noticed that it is a gear that has the function to trigger,The gearbox has probably moved out of its original position and is now not turning the read head.How do I return the gear to the original position so that it re-engages the bedhead?
Add a comment
