필요한 것
Pull out the charging port (DC input terminal) cover and remove the 4-mm screw located next to the input terminal.
Flip out the LCD screen to expose the inner screws. Remove the two black 4-mm screws.
Using a firm hold on both sides of the camcorder, gently pull apart the casing under the hand strap.
이 단계에 사용된 도구:Tweezers$4.99
Use tweezers to grab the ribbon cable at the connection point and slowly lift it away from the connector.
거의 끝나갑니다!
결론
