주요 콘텐츠로 건너뛰기
Panasonic Toughbook CF-29 Back Cover Replacement
필요한 것
  1. Panasonic Toughbook CF-29 Back Cover Replacement, Battery: 1 단계, 이미지 1/1
    • Locate the bay door for the battery on the left side of the laptop.
  2. Panasonic Toughbook CF-29 Back Cover Replacement: 2 단계, 이미지 1/2 Panasonic Toughbook CF-29 Back Cover Replacement: 2 단계, 이미지 2/2
    • Slide the latch to the right and then down to unlock it.
    • Pull out the battery.
  3. Panasonic Toughbook CF-29 Back Cover Replacement, Optical Drive: 3 단계, 이미지 1/1
    • Flip the device upside down with the handle facing away from you.
    • Open the optical drive bay by sliding its latch to the right.
    • Locate optical drive release mechanism on the bottom of the laptop.
  4. Panasonic Toughbook CF-29 Back Cover Replacement: 4 단계, 이미지 1/1
    • Slide the latch cover to the right.
  5. Panasonic Toughbook CF-29 Back Cover Replacement: 5 단계, 이미지 1/2 Panasonic Toughbook CF-29 Back Cover Replacement: 5 단계, 이미지 2/2
    • Push the exposed switch to the left to eject the optical drive.
  6. Panasonic Toughbook CF-29 Back Cover Replacement, Back Cover: 6 단계, 이미지 1/1
    • Begin by turning the laptop upside down with the handle towards you.
    • Use a Phillips size 0 screwdriver to remove the 4 screws holding down the ram cover.
  7. Panasonic Toughbook CF-29 Back Cover Replacement: 7 단계, 이미지 1/1
    • Remove the panel and set it aside.
    • Use a Phillips size 0 screwdriver to remove these 8 small screws.
  8. Panasonic Toughbook CF-29 Back Cover Replacement: 8 단계, 이미지 1/1
    • Use a Phillips size 1 screwdriver to remove the remaining 8 screws.
  9. Panasonic Toughbook CF-29 Back Cover Replacement: 9 단계, 이미지 1/2 Panasonic Toughbook CF-29 Back Cover Replacement: 9 단계, 이미지 2/2
    • Use a plastic opening tool to release, but NOT remove, the back cover because it is sealed with adhesive.
  10. Panasonic Toughbook CF-29 Back Cover Replacement: 10 단계, 이미지 1/1
    • Be careful when lifting the cover as you may damage some connections.
    • Slowly lift the cover so that you can disconnect the red and white wires connecting the speaker to the sound card.
  11. Panasonic Toughbook CF-29 Back Cover Replacement: 11 단계, 이미지 1/1
    • Now the back cover should be off and you can access the inside of the casing.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Rohun Heesen
회원 가입일: 04/13/10
426 평판
안내서 2개 작성하였습니다
Cal Poly, Team 27-93, Amido Spring 2010 Cal Poly, Team 27-93, Amido Spring 2010 회원
CPSU-AMIDO-S10S27G93
4 회원들
안내서 26개 작성하였습니다
댓글 한 개
thanks for this crucial tuatorial >
Joe Gutierrez - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 13
전체 시간: 10,095
