주요 콘텐츠로 건너뛰기
Panasonic Toughbook CF-29 Heat Sink Replacement
필요한 것
  1. Panasonic Toughbook CF-29 Heat Sink Replacement, Battery: 1 단계, 이미지 1/1
    • Locate the bay door for the battery on the left side of the laptop.
  2. Panasonic Toughbook CF-29 Heat Sink Replacement: 2 단계, 이미지 1/2 Panasonic Toughbook CF-29 Heat Sink Replacement: 2 단계, 이미지 2/2
    • Slide the latch to the right and then down to unlock it.
    • Pull out the battery.
  3. Panasonic Toughbook CF-29 Heat Sink Replacement, Back Cover: 3 단계, 이미지 1/1
    • Begin by turning the laptop upside down with the handle towards you.
    • Use a Phillips size 0 screwdriver to remove the 4 screws holding down the ram cover.
  4. Panasonic Toughbook CF-29 Heat Sink Replacement: 4 단계, 이미지 1/1
    • Remove the panel and set it aside.
    • Use a Phillips size 0 screwdriver to remove these 8 small screws.
  5. Panasonic Toughbook CF-29 Heat Sink Replacement: 5 단계, 이미지 1/1
    • Use a Phillips size 1 screwdriver to remove the remaining 8 screws.
  6. Panasonic Toughbook CF-29 Heat Sink Replacement: 6 단계, 이미지 1/2 Panasonic Toughbook CF-29 Heat Sink Replacement: 6 단계, 이미지 2/2
    • Use a plastic opening tool to release, but NOT remove, the back cover because it is sealed with adhesive.
  7. Panasonic Toughbook CF-29 Heat Sink Replacement: 7 단계, 이미지 1/1
    • Be careful when lifting the cover as you may damage some connections.
    • Slowly lift the cover so that you can disconnect the red and white wires connecting the speaker to the sound card.
  8. Panasonic Toughbook CF-29 Heat Sink Replacement: 8 단계, 이미지 1/1
    • Now the back cover should be off and you can access the inside of the casing.
  9. Panasonic Toughbook CF-29 Heat Sink Replacement, Heat Sink: 9 단계, 이미지 1/1
    • Locate the heat sink on the underside of the back cover.
    • It is the U shaped metallic piece.
  10. Panasonic Toughbook CF-29 Heat Sink Replacement: 10 단계, 이미지 1/1
    • Remove the four screws with a Phillips size 1 screwdriver.
    • One on each of the ends
    • Two on the base of the U shape
  11. Panasonic Toughbook CF-29 Heat Sink Replacement: 11 단계, 이미지 1/1
    • Being careful not to lose the brackets at the ends of the heat sink, lift it up and out.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Clint Kirsop
회원 가입일: 04/13/10
109 평판
안내서 4개 작성하였습니다
Cal Poly, Team 27-93, Amido Spring 2010 Cal Poly, Team 27-93, Amido Spring 2010 회원
CPSU-AMIDO-S10S27G93
4 회원들
안내서 26개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 5,833
