주요 콘텐츠로 건너뛰기
Panasonic Toughbook CF-29 Keyboard Replacement
필요한 것
  1. Panasonic Toughbook CF-29 Keyboard Replacement, Battery: 1 단계, 이미지 1/1
    • Locate the bay door for the battery on the left side of the laptop.
  2. Panasonic Toughbook CF-29 Keyboard Replacement: 2 단계, 이미지 1/2 Panasonic Toughbook CF-29 Keyboard Replacement: 2 단계, 이미지 2/2
    • Slide the latch to the right and then down to unlock it.
    • Pull out the battery.
  3. Panasonic Toughbook CF-29 Keyboard Replacement, Keyboard: 3 단계, 이미지 1/1
    • Remove the four screws above the keyboard using a Phillips #0 screwdriver.
  4. Panasonic Toughbook CF-29 Keyboard Replacement: 4 단계, 이미지 1/1
    • Pry up the black panel covering the top of the keyboard.
  5. Panasonic Toughbook CF-29 Keyboard Replacement: 5 단계, 이미지 1/1
    • Remove the five silver screws shown.
  6. Panasonic Toughbook CF-29 Keyboard Replacement: 6 단계, 이미지 1/1
    • Pull up keyboard and place it face down on the trackpad
    • Be careful not to put tension in the ribbon cables attached to the underside of the keyboard
  7. Panasonic Toughbook CF-29 Keyboard Replacement: 7 단계, 이미지 1/1
    • Remove screws shown from cover plate
  8. Panasonic Toughbook CF-29 Keyboard Replacement: 8 단계, 이미지 1/2 Panasonic Toughbook CF-29 Keyboard Replacement: 8 단계, 이미지 2/2
    • Pull cover plate out of place revealing the ribbon cable connections to the motherboard
  9. Panasonic Toughbook CF-29 Keyboard Replacement: 9 단계, 이미지 1/2 Panasonic Toughbook CF-29 Keyboard Replacement: 9 단계, 이미지 2/2
    • Remove the ribbon cable farthest from you.
    • Push the white tab (as shown in the second photo) to release the ribbon cable.
  10. Panasonic Toughbook CF-29 Keyboard Replacement: 10 단계, 이미지 1/1
    • Remove both ribbon cable by pulling 2 white tabs on either side of the cable to the right
결론
다른 3명이 해당 안내서를 완성하였습니다.
Dylan Bloom
회원 가입일: 04/12/10
373 평판
안내서 4개 작성하였습니다
Cal Poly, Team 27-93, Amido Spring 2010 Cal Poly, Team 27-93, Amido Spring 2010 회원
CPSU-AMIDO-S10S27G93
4 회원들
안내서 26개 작성하였습니다
댓글 한 개
When replacing the KB, don'f forget the double sided fiberglass tape. The regular CF-29 KB is a backbone of thin aluminum sheeting, Most likely when you "pop" off the KB, its likely to bend. When you install a bent KB, it bounces when you type. Bend it back and tape it down with new tape. With the CF-30, removing that KB is totally different. Its locked down by brackets, not taped. You need to slide it forward unlocking it before popping it off, otherwise your KB keys start breaking. Be soft and confident, because you bet one chance to do it correctly. Sponsored by Black Hawk Toughbooks.
Black Hawk - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 20
전체 시간: 17,192
