이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove the four screws above the keyboard using a Phillips #0 screwdriver.
Pull cover plate out of place revealing the ribbon cable connections to the motherboard
Remove the ribbon cable farthest from you.
Push the white tab (as shown in the second photo) to release the ribbon cable.
Remove both ribbon cable by pulling 2 white tabs on either side of the cable to the right
다른 3명이 해당 안내서를 완성하였습니다.
댓글 한 개
When replacing the KB, don'f forget the double sided fiberglass tape. The regular CF-29 KB is a backbone of thin aluminum sheeting, Most likely when you "pop" off the KB, its likely to bend. When you install a bent KB, it bounces when you type. Bend it back and tape it down with new tape. With the CF-30, removing that KB is totally different. Its locked down by brackets, not taped. You need to slide it forward unlocking it before popping it off, otherwise your KB keys start breaking. Be soft and confident, because you bet one chance to do it correctly. Sponsored by Black Hawk Toughbooks.
Black Hawk - 답글
