주요 콘텐츠로 건너뛰기
Panasonic Toughbook CF-29 Optical Drive Replacement
  1. Panasonic Toughbook CF-29 Optical Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Locate the bay door for the battery on the left side of the laptop.
  2. Panasonic Toughbook CF-29 Optical Drive Replacement: 2 단계, 이미지 1/2 Panasonic Toughbook CF-29 Optical Drive Replacement: 2 단계, 이미지 2/2
    • Slide the latch to the right and then down to unlock it.
    • Pull out the battery.
  3. Panasonic Toughbook CF-29 Optical Drive Replacement, Optical Drive: 3 단계, 이미지 1/1
    • Flip the device upside down with the handle facing away from you.
    • Open the optical drive bay by sliding its latch to the right.
    • Locate optical drive release mechanism on the bottom of the laptop.
  4. Panasonic Toughbook CF-29 Optical Drive Replacement: 4 단계, 이미지 1/1
    • Slide the latch cover to the right.
  5. Panasonic Toughbook CF-29 Optical Drive Replacement: 5 단계, 이미지 1/2 Panasonic Toughbook CF-29 Optical Drive Replacement: 5 단계, 이미지 2/2
    • Push the exposed switch to the left to eject the optical drive.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Clint Kirsop
회원 가입일: 04/13/10
109 평판
안내서 4개 작성하였습니다
Cal Poly, Team 27-93, Amido Spring 2010 Cal Poly, Team 27-93, Amido Spring 2010 회원
CPSU-AMIDO-S10S27G93
4 회원들
안내서 26개 작성하였습니다
댓글 한 개
What kind of USB enclosure would this fit in?
Terence Higgins - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 11
전체 시간: 6,829
