주요 콘텐츠로 건너뛰기
Panasonic Toughbook CF-29 RAM Replacement
필요한 것
  1. Panasonic Toughbook CF-29 RAM Replacement, Battery: 1 단계, 이미지 1/1
    • Locate the bay door for the battery on the left side of the laptop.
  2. Panasonic Toughbook CF-29 RAM Replacement: 2 단계, 이미지 1/2 Panasonic Toughbook CF-29 RAM Replacement: 2 단계, 이미지 2/2
    • Slide the latch to the right and then down to unlock it.
    • Pull out the battery.
  3. Panasonic Toughbook CF-29 RAM Replacement, RAM: 3 단계, 이미지 1/1
    • Use a Phillips size 0 screwdriver to remove the 4 screws holding down the ram cover.
  4. Panasonic Toughbook CF-29 RAM Replacement: 4 단계, 이미지 1/1
    • Pull the clips aside to release and remove the RAM.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Devon Augustus
회원 가입일: 04/12/10
130 평판
안내서 2개 작성하였습니다
Cal Poly, Team 27-93, Amido Spring 2010 Cal Poly, Team 27-93, Amido Spring 2010 회원
CPSU-AMIDO-S10S27G93
4 회원들
안내서 26개 작성하였습니다
댓글 2개
Thanks for sharing this. I just bought a panasonic toughbook from http://buytough.com and I think this will come in handy. :)
Katie Sutton - 답글
there is another ram slot you failed to mention
sparkynaz - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 13
전체 시간: 18,307
