주요 콘텐츠로 건너뛰기
Panasonic Toughbook CF-29 Trackpad Board Replacement
필요한 것
  1. Panasonic Toughbook CF-29 Trackpad Board Replacement, Battery: 1 단계, 이미지 1/1
    • Locate the bay door for the battery on the left side of the laptop.
  2. Panasonic Toughbook CF-29 Trackpad Board Replacement: 2 단계, 이미지 1/2 Panasonic Toughbook CF-29 Trackpad Board Replacement: 2 단계, 이미지 2/2
    • Slide the latch to the right and then down to unlock it.
    • Pull out the battery.
  3. Panasonic Toughbook CF-29 Trackpad Board Replacement, Hard Drive: 3 단계, 이미지 1/1
    • Locate the door for the hard drive on the right side of the laptop
  4. Panasonic Toughbook CF-29 Trackpad Board Replacement: 4 단계, 이미지 1/2 Panasonic Toughbook CF-29 Trackpad Board Replacement: 4 단계, 이미지 2/2
    • Push and slide the latch up to open the hard drive door.
    • Pull out the hard drive.
  5. Panasonic Toughbook CF-29 Trackpad Board Replacement, Optical Drive: 5 단계, 이미지 1/1
    • Flip the device upside down with the handle facing away from you.
    • Open the optical drive bay by sliding its latch to the right.
    • Locate optical drive release mechanism on the bottom of the laptop.
  6. Panasonic Toughbook CF-29 Trackpad Board Replacement: 6 단계, 이미지 1/1
    • Slide the latch cover to the right.
  7. Panasonic Toughbook CF-29 Trackpad Board Replacement: 7 단계, 이미지 1/2 Panasonic Toughbook CF-29 Trackpad Board Replacement: 7 단계, 이미지 2/2
    • Push the exposed switch to the left to eject the optical drive.
  8. Panasonic Toughbook CF-29 Trackpad Board Replacement, Back Cover: 8 단계, 이미지 1/1
    • Begin by turning the laptop upside down with the handle towards you.
    • Use a Phillips size 0 screwdriver to remove the 4 screws holding down the ram cover.
  9. Panasonic Toughbook CF-29 Trackpad Board Replacement: 9 단계, 이미지 1/1
    • Remove the panel and set it aside.
    • Use a Phillips size 0 screwdriver to remove these 8 small screws.
  10. Panasonic Toughbook CF-29 Trackpad Board Replacement: 10 단계, 이미지 1/1
    • Use a Phillips size 1 screwdriver to remove the remaining 8 screws.
  11. Panasonic Toughbook CF-29 Trackpad Board Replacement: 11 단계, 이미지 1/2 Panasonic Toughbook CF-29 Trackpad Board Replacement: 11 단계, 이미지 2/2
    • Use a plastic opening tool to release, but NOT remove, the back cover because it is sealed with adhesive.
  12. Panasonic Toughbook CF-29 Trackpad Board Replacement: 12 단계, 이미지 1/1
    • Be careful when lifting the cover as you may damage some connections.
    • Slowly lift the cover so that you can disconnect the red and white wires connecting the speaker to the sound card.
  13. Panasonic Toughbook CF-29 Trackpad Board Replacement: 13 단계, 이미지 1/1
    • Now the back cover should be off and you can access the inside of the casing.
  14. Panasonic Toughbook CF-29 Trackpad Board Replacement, Trackpad Board: 14 단계, 이미지 1/1
    • Locate the track pad chip near the handle.
    • Remove the upper right screw.
  15. Panasonic Toughbook CF-29 Trackpad Board Replacement: 15 단계, 이미지 1/1
    • Use a pry bar to detach the white ribbon cable shown.
    • Push the brown tab to release the cable
  16. Panasonic Toughbook CF-29 Trackpad Board Replacement: 16 단계, 이미지 1/1
    • Remove the screw that was previously concealed under the now removed ribbon cable.
  17. Panasonic Toughbook CF-29 Trackpad Board Replacement: 17 단계, 이미지 1/1
    • Remove the rightmost ribbon cable
    • Pry up the brown clip
    • Tug the cable out
  18. Panasonic Toughbook CF-29 Trackpad Board Replacement: 18 단계, 이미지 1/1
    • Pull the track pad slightly up and to the right.
    • Do not completely remove the circuit board because it is still attached.
  19. Panasonic Toughbook CF-29 Trackpad Board Replacement: 19 단계, 이미지 1/1
    • Remove the last ribbon cable.
    • Pry up on the brown part to release the ribbon cable.
  20. Panasonic Toughbook CF-29 Trackpad Board Replacement: 20 단계, 이미지 1/1
    • You have successfully removed the track pad board.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Dylan Bloom
회원 가입일: 04/12/10
373 평판
안내서 4개 작성하였습니다
Cal Poly, Team 27-93, Amido Spring 2010 Cal Poly, Team 27-93, Amido Spring 2010 회원
CPSU-AMIDO-S10S27G93
4 회원들
안내서 26개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 9
전체 시간: 5,835
