주요 콘텐츠로 건너뛰기
Panasonic Toughbook CF-53 Battery Replacement
  1. Panasonic Toughbook CF-53 Battery Replacement, Battery: 1 단계, 이미지 1/3 Panasonic Toughbook CF-53 Battery Replacement, Battery: 1 단계, 이미지 2/3 Panasonic Toughbook CF-53 Battery Replacement, Battery: 1 단계, 이미지 3/3
    • Orient the laptop on its side so that the plastic battery cover is facing upward.
    • Push down on the battery cover and remove it by sliding the cover down. This may take some force, but the cover should pop up with a soft click.
  2. Panasonic Toughbook CF-53 Battery Replacement: 2 단계, 이미지 1/2 Panasonic Toughbook CF-53 Battery Replacement: 2 단계, 이미지 2/2
    • Use the battery release slider to release the battery latch.
  3. Panasonic Toughbook CF-53 Battery Replacement: 3 단계, 이미지 1/3 Panasonic Toughbook CF-53 Battery Replacement: 3 단계, 이미지 2/3 Panasonic Toughbook CF-53 Battery Replacement: 3 단계, 이미지 3/3
    • Use the blue tab to pull the battery out of the battery compartment. Make sure to keep the battery latch tab depressed while doing so.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Gage Russello
회원 가입일: 09/20/19
154 평판
안내서 1개 작성함
댓글 한 개
I replaced the battery compatible one and replace the power adapter as well but still shows no power. What other issues may cause no power?
Rick Reeves - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 20
30일 전: 72
전체 시간: 6,059
