주요 콘텐츠로 건너뛰기
Panasonic Toughbook CF-53 Hard Drive Replacement
필요한 것
  1. Panasonic Toughbook CF-53 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 3개 중 1개 Panasonic Toughbook CF-53 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 3개 중 2개 Panasonic Toughbook CF-53 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 3개 중 3개
    • Locate the hard drive enclosure release latch in the top left corner. While pulling it down, lift the enclosure up and out of the laptop.
    • You may need to use a spudger or mini flat blade screwdriver to grab onto the lip of the drive enclosure and pull it out.
  2. Panasonic Toughbook CF-53 Hard Drive Replacement: 2 단계, 이미지 3개 중 1개 Panasonic Toughbook CF-53 Hard Drive Replacement: 2 단계, 이미지 3개 중 2개 Panasonic Toughbook CF-53 Hard Drive Replacement: 2 단계, 이미지 3개 중 3개
    • Flip the drive black side down.
    • Place six opening picks between the black outer casing and metallic inner casing to disengage the five metal clips connecting the inner and outer casings.
    • Once all the clips have been freed from their holes, you can now lift the inner casing up and out of the outer casing.
  3. Panasonic Toughbook CF-53 Hard Drive Replacement: 3 단계, 이미지 3개 중 1개 Panasonic Toughbook CF-53 Hard Drive Replacement: 3 단계, 이미지 3개 중 2개 Panasonic Toughbook CF-53 Hard Drive Replacement: 3 단계, 이미지 3개 중 3개
    • Gently pull the hard drive assembly from the inner drive casing.
    • Using a spudger, gently remove the two adhesive pads holding the paper dust cover in place.
    • If you have a replacement dust cover, you can simply just cut the old cover off. You will need new adhesive pads if you have a new cover or are reusing the old one.
  4. Panasonic Toughbook CF-53 Hard Drive Replacement: 4 단계, 이미지 3개 중 1개 Panasonic Toughbook CF-53 Hard Drive Replacement: 4 단계, 이미지 3개 중 2개 Panasonic Toughbook CF-53 Hard Drive Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the SATA adapter from the hard drive by simply unplugging it.
    • When reinserting the hard drive into the drive cover, ensure that you line the circuit board of the SATA adapter with its slot. This is the connector shown in the final image.
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Sean Marsden
회원 가입일: 09/16/19
688 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 8
지난 30일: 78
전체 시간: 8,502
