주요 콘텐츠로 건너뛰기
Panasonic Toughbook CF-53 Optical Drive Replacement
필요한 것
  1. Panasonic Toughbook CF-53 Optical Drive Replacement, Optical Drive: 1 단계, 이미지 1/2 Panasonic Toughbook CF-53 Optical Drive Replacement, Optical Drive: 1 단계, 이미지 2/2
    • Orient the laptop onto its top and face the bottom towards you.
    • Remove the 3 mm Phillips #00 screws securing the Wi-Fi card/optical drive plastic cover.
  2. Panasonic Toughbook CF-53 Optical Drive Replacement: 2 단계, 이미지 1/1
    • Remove the 5 mm Phillips #00 screw on the silver tab to the left.
  3. Panasonic Toughbook CF-53 Optical Drive Replacement: 3 단계, 이미지 1/1
    • Reach under the silver tab and push the optical drive out of the side of the device using a spudger.
  4. Panasonic Toughbook CF-53 Optical Drive Replacement: 4 단계, 이미지 1/1
    • Now that the drive is completely disconnected from the device, slide the optical drive out of its slot.
    • The end of the drive may seem to be stuck inside the device during removal. If this is the case gently wiggle the drive side to side and apply a small force until it pops free.
결론
Sean Marsden
회원 가입일: 09/16/19
613 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 16
전체 시간: 1,614
