주요 콘텐츠로 건너뛰기
Panasonic VDR-D220 DVD Camera Front lens Element Replacement
필요한 것
  1. Panasonic VDR-D220 DVD Camera Front lens Element Replacement, Camera lens: 1 단계, 이미지 1/3 Panasonic VDR-D220 DVD Camera Front lens Element Replacement, Camera lens: 1 단계, 이미지 2/3 Panasonic VDR-D220 DVD Camera Front lens Element Replacement, Camera lens: 1 단계, 이미지 3/3
    • Remove one 5mm screw on the bottom side of the camera with a Phillips #0 screwdriver.
  2. Panasonic VDR-D220 DVD Camera Front lens Element Replacement: 2 단계, 이미지 1/3 Panasonic VDR-D220 DVD Camera Front lens Element Replacement: 2 단계, 이미지 2/3 Panasonic VDR-D220 DVD Camera Front lens Element Replacement: 2 단계, 이미지 3/3
    • Open the side port door.
  3. Panasonic VDR-D220 DVD Camera Front lens Element Replacement: 3 단계, 이미지 1/2 Panasonic VDR-D220 DVD Camera Front lens Element Replacement: 3 단계, 이미지 2/2
    • Remove one 5mm screw inside the side port with your Phillips #0 screwdriver.
  4. Panasonic VDR-D220 DVD Camera Front lens Element Replacement: 4 단계, 이미지 1/2 Panasonic VDR-D220 DVD Camera Front lens Element Replacement: 4 단계, 이미지 2/2
    • Using a plastic spudger, pry to disconnect the top-front part of the camera.
    • Slide the top portion of the camera forward revealing a ribbon cable.
  5. Panasonic VDR-D220 DVD Camera Front lens Element Replacement: 5 단계, 이미지 1/3 Panasonic VDR-D220 DVD Camera Front lens Element Replacement: 5 단계, 이미지 2/3 Panasonic VDR-D220 DVD Camera Front lens Element Replacement: 5 단계, 이미지 3/3
    • Flip the camera on the right side.
    • Gently pull the front part from the main body to reveal the cables connecting them.
    • Do not pull too hard because of the ZIF connector cable.
    • Use your plastic opening tool to disconnect the connection point safely.
    • Press the tab with a plastic opening tool and then pull the ZIF connector to detach.
  6. Panasonic VDR-D220 DVD Camera Front lens Element Replacement: 6 단계, 이미지 1/3 Panasonic VDR-D220 DVD Camera Front lens Element Replacement: 6 단계, 이미지 2/3 Panasonic VDR-D220 DVD Camera Front lens Element Replacement: 6 단계, 이미지 3/3
    • Look at the camera from the front side.
    • Remove four 5mm screws using a Phillips #0 screwdriver.
    • There are two 5mm screws on each side of the lens, for a total of four screws.
  7. Panasonic VDR-D220 DVD Camera Front lens Element Replacement: 7 단계, 이미지 1/3 Panasonic VDR-D220 DVD Camera Front lens Element Replacement: 7 단계, 이미지 2/3 Panasonic VDR-D220 DVD Camera Front lens Element Replacement: 7 단계, 이미지 3/3
    • Pull the front element lens gently away from the camera.
    • In some cases the lens need not be replaced completely. Sometimes cleaning the lens with a microfiber cloth and isopropyl alcohol will alleviate blurry video issues.
결론
Brandon Gregoire
회원 가입일: 09/18/19
1,325 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 10
전체 시간: 192
