주요 콘텐츠로 건너뛰기
Panasonic VDR-D220 DVD Disk Latch Replacement
필요한 것
  1. Panasonic VDR-D220 DVD Disk Latch Replacement, Disk Latch: 1 단계, 이미지 1/2 Panasonic VDR-D220 DVD Disk Latch Replacement, Disk Latch: 1 단계, 이미지 2/2
    • The DVD's door can be opened by pressing the top-left of the DVD's door.
    • If this doesn’t work, you may need to manually eject.
    • Use the plastic spudger with light force to carefully pry open the door.
    • Open the disk ejection slot gently.
  2. Panasonic VDR-D220 DVD Disk Latch Replacement: 2 단계, 이미지 1/3 Panasonic VDR-D220 DVD Disk Latch Replacement: 2 단계, 이미지 2/3 Panasonic VDR-D220 DVD Disk Latch Replacement: 2 단계, 이미지 3/3
    • Remove the two 5mm screws on the top-right corner of the disk slot using Phillips #0 screwdriver.
  3. Panasonic VDR-D220 DVD Disk Latch Replacement: 3 단계, 이미지 1/2 Panasonic VDR-D220 DVD Disk Latch Replacement: 3 단계, 이미지 2/2
    • Carefully remove the chip.
    • The disk is completely replaced/removed.
결론
Tianyi Luo
회원 가입일: 09/22/19
97 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 143
