주요 콘텐츠로 건너뛰기
Pantech Breakout Micro SD/SIM Card Replacement
  1. Pantech Breakout Micro SD/SIM Card Replacement, Removing Back Cover: 1 단계, 이미지 3개 중 1개 Pantech Breakout Micro SD/SIM Card Replacement, Removing Back Cover: 1 단계, 이미지 3개 중 2개 Pantech Breakout Micro SD/SIM Card Replacement, Removing Back Cover: 1 단계, 이미지 3개 중 3개
    • Before proceeding, completely power off phone and disconnect power cords to avoid electrical shock.
    • Turn phone over so that the back side is facing up.
    • Using a finger, apply moderate pressure to the top of the back cover while sliding the cover down and off.
    • Lift and remove the back cover from the phone.
  2. Pantech Breakout Micro SD/SIM Card Replacement, Removing the Battery: 2 단계, 이미지 2개 중 1개 Pantech Breakout Micro SD/SIM Card Replacement, Removing the Battery: 2 단계, 이미지 2개 중 2개
    • Locate the battery: It is a silver, rectangular object.
    • Insert a fingernail into the indent just below the battery about 0.5 inches from the bottom of the phone.
    • Then, apply pressure to the battery, pushing up and away from the phone. It will come out easily.
  3. Pantech Breakout Micro SD/SIM Card Replacement, Inserting Micro SD or SIM Card: 3 단계, 이미지 2개 중 1개 Pantech Breakout Micro SD/SIM Card Replacement, Inserting Micro SD or SIM Card: 3 단계, 이미지 2개 중 2개
    • The slots for the Micro SD and SIM cards are directly above the battery tray.
    • To insert a card, slide it face up into the slot. To remove a card, slide the card out from the slot.
    • Micro SD Card Slot - On the Left
    • SIM Card Slot - On the Right
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Ryan Murphy
회원 가입일: 09/25/14
898 평판
안내서 7개를 작성함
USF Tampa, Team 5-5, Mcgee Fall 2014 USF Tampa, Team 5-5, Mcgee Fall 2014 회원
USFT-MCGEE-F14S5G5
4 회원들
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 17
전체 시간: 2,778
