주요 콘텐츠로 건너뛰기
Pantech Burst Motherboard Replacement
필요한 것
  1. Pantech Burst Motherboard Replacement, Motherboard: 1 단계, 이미지 1/3 Pantech Burst Motherboard Replacement, Motherboard: 1 단계, 이미지 2/3 Pantech Burst Motherboard Replacement, Motherboard: 1 단계, 이미지 3/3
    • Power off your phone before beginning disassembly.
    • Turn over the phone so that you're facing the back cover.
    • Locate the indent(?) below the back cover.
    • Using a fingernail, pull up to remove the back cover.
    • Removing the back cover may require some force.
  2. Pantech Burst Motherboard Replacement: 2 단계, 이미지 1/3 Pantech Burst Motherboard Replacement: 2 단계, 이미지 2/3 Pantech Burst Motherboard Replacement: 2 단계, 이미지 3/3
    • Locate the silver battery. It is the big, rectangular, silver tape on black plastic object.
    • Find the gap between the battery and the rest of the device.
    • Using your fingernail, gently pull the battery up and away from the rest of the device.
  3. Pantech Burst Motherboard Replacement: 3 단계, 이미지 1/3 Pantech Burst Motherboard Replacement: 3 단계, 이미지 2/3 Pantech Burst Motherboard Replacement: 3 단계, 이미지 3/3
    • Undo all 8 visible screws using a phillips size 000 screwdriver.
    • The screws are marked in red on the picture.
  4. Pantech Burst Motherboard Replacement: 4 단계, 이미지 1/2 Pantech Burst Motherboard Replacement: 4 단계, 이미지 2/2
    • Remove the SD card if there is one inserted into the phone.
  5. Pantech Burst Motherboard Replacement: 5 단계, 이미지 1/3 Pantech Burst Motherboard Replacement: 5 단계, 이미지 2/3 Pantech Burst Motherboard Replacement: 5 단계, 이미지 3/3
    • Using an opening tool or some other solid, flat-ended tool, begin pulling apart the phone from the indent below the USB port.
    • Continue using the tool, while moving around the edge of the phone until the two parts are largely disengaged.
    • Once there is space enough to pull the pieces apart with your fingers, you may do so.
    • Opening the phone may require a good amount of force.
  6. Pantech Burst Motherboard Replacement: 6 단계, 이미지 1/3 Pantech Burst Motherboard Replacement: 6 단계, 이미지 2/3 Pantech Burst Motherboard Replacement: 6 단계, 이미지 3/3
    • Unscrew the screw with a phillips size 000 screwdriver.
    • Disconnect the blue connector from the motherboard using a fingernail to lightly pull up.
    • Gently remove the SIM/SD card part.
  7. Pantech Burst Motherboard Replacement: 7 단계, 이미지 1/1
    • Gently disconnect the connectors attached to the motherboard using a fingernail to pull them up from the board.
    • Connectors are marked in blue in the image.
  8. Pantech Burst Motherboard Replacement: 8 단계, 이미지 1/3 Pantech Burst Motherboard Replacement: 8 단계, 이미지 2/3 Pantech Burst Motherboard Replacement: 8 단계, 이미지 3/3
    • Starting from the bottom and going around counterclockwise, carefully pry the motherboard out of the device.
    • Beginning with the side with the USB port may damage the phone.
결론
Kyle Kurashima
회원 가입일: 09/29/15
111 평판
안내서 1개 작성함
Cal Poly, Team 15-1, Green Fall 2015 Cal Poly, Team 15-1, Green Fall 2015 회원
CPSU-GREEN-F15S15G1
5 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 10
전체 시간: 429
