주요 콘텐츠로 건너뛰기
Pantech CDM8975 Screen Replacement
필요한 것
  1. Pantech CDM8975 Screen Replacement, Screen: 1 단계, 이미지 1개 중 1개
    • Open the flip phone so that the screen and keyboard are facing you.
  2. Pantech CDM8975 Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the four screws at the corners of the screen.
  3. Pantech CDM8975 Screen Replacement: 3 단계, 이미지 2개 중 1개 Pantech CDM8975 Screen Replacement: 3 단계, 이미지 2개 중 2개
    • Use a spudger to separate the back shield from the top half of the phone.
    • Warning: Remove the battery prior to removing the screen.
  4. Pantech CDM8975 Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Set the phone down with the exposed side facing up.
  5. Pantech CDM8975 Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Near the hinge of the phone there is a green circuit board.
    • On the underside of the board, there is an orange plastic connector that connects the battery to the screen.
    • The LCD screen is the metal square with the black LCD screen in the middle (this should not be confused with the clear plastic protective screen on the front of the phone).
    • Pull the LCD screen out with your fingers and disconnect the circuit board from the orange plastic connector with the spudger.
  6. Pantech CDM8975 Screen Replacement: 6 단계, 이미지 1개 중 1개
    • The original LCD screen will have components (like a microphone, speakers, etc.) attached by wires. If your replacement LCD screen is similar, then take out the original LCD screen (with attachments) and replace it with the new LCD screen. You can skip steps 8-11, since they do not apply to this situation.
    • Note: If your replacement LCD screen did not come with components (like microphone, speakers, etc.) attached, then continue with the guide as written.
    • Using wire cutters, disconnect the speaker from the phone.
    • Your phone will look different from these pictures, since the cutting steps have not been performed. Follow the steps in the guide for true instructions - pictures are only to help illustrate locations of steps.
  7. Pantech CDM8975 Screen Replacement: 7 단계, 이미지 1개 중 1개
    • Pull the wires from the screen which connect to the speaker carefully.
  8. Pantech CDM8975 Screen Replacement: 8 단계, 이미지 2개 중 1개 Pantech CDM8975 Screen Replacement: 8 단계, 이미지 2개 중 2개
    • Carefully remove the screen. Leave the wires from the speakers exposed (top of the phone).
  9. Pantech CDM8975 Screen Replacement: 9 단계, 이미지 2개 중 1개 Pantech CDM8975 Screen Replacement: 9 단계, 이미지 2개 중 2개
    • Make sure all of the wires are out of the way before inserting new screen.
  10. Pantech CDM8975 Screen Replacement: 10 단계, 이미지 1개 중 1개
    • Put the new screen into the phone.
    • Solder wires into screen if necessary.
  11. Pantech CDM8975 Screen Replacement: 11 단계, 이미지 1개 중 1개
    • Reattach the backing of the phone with the four screws.
    • Your phone should now be operational (after reinserting the battery). If it is not, revisit the steps, and make sure everything was reassembled correctly.
    • If your phone turns on and displays, you are finished!
결승점
작성자
10다른 기여자 명과 함께
Chris
회원 가입일: 02/13/14
1 평판
안내서 1개를 작성함
Ohio State, Team 1-4, Meza Spring 2014 Ohio State, Team 1-4, Meza Spring 2014 회원
OSU-MEZA-S14S1G4
4 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 9
전체 시간: 552
